ECU's
Old Nov 5, 2003 | 08:21 PM
casper625's Avatar
Default ECU's
I have a 94 h22a whats the best ecu for it (chip or no chip)
Old Nov 5, 2003 | 08:25 PM
PrecisionH23a's Avatar
Default Re: ECU's (casper625)
Chips are a waste of money. Usually they give you a tad bit more timing, a higher rev limit (which you probably dont need on your motor), and slightly adjust your fuel tables.
First of all it depends on what your motor is geared towards... N/A or FI. Then you have to keep in mind no two motors are the same, so they will require different ignition and fuel tables.
If you are running a stock car or slightly modded motor, keep your stock ecu and run a V-AFC. If you are looking at 200whp all motor or go FI, then I recommend hondata.
HiroshimaScreamer
19
Feb 4, 2015 01:03 PM
spurge
Nov 3, 2006 09:37 AM
mellowboy
Jan 28, 2003 02:12 PM
boostedsi99
Jul 26, 2002 12:05 PM
HondasRfast
Mar 29, 2002 03:18 PM
