Throwing codes?
Old Apr 12, 2004 | 07:41 PM
NobodysHero's Avatar
Default Throwing codes?
What do people mean when they use the term "throwing codes"? I'm swapping my h23 with a jdm h22, and i've heard people say that if somethings not right, it will start throwing codes. What does this mean exactly.
Old Apr 12, 2004 | 07:53 PM
Hawkze_2.3's Avatar
Default Re: Throwing codes? (NobodysHero)
Check engine light...(CEL)....
Old Apr 13, 2004 | 01:08 PM
How do you know what code the car is throwing?
Old Apr 13, 2004 | 01:15 PM
RAB's Avatar
RAB
Default Re: (NobodysHero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NobodysHero &raquo;</TD></TR><TR><TD CLASS="quote">How do you know what code the car is throwing?</TD></TR></TABLE>
Is the check engine light (CEL)(orange) on or flashing. If yes then the computer has detected a problem. If no then the computer has not detected a problem.
Old Apr 15, 2004 | 02:08 PM
99GreenLude's Avatar
To find out how to read the CEL codes, you have to bridge the wires in the dash, behind and to the right of the ashtray (5th gen). There are two wires connected to a black adapter. You have to put a wire into each of these to bridge the wires so they are touching. After this, turn your car onto the accessory position and watch the CEL and count the flashes. The long flashes are multiples of ten and the quick flases are represented by one's. Example...six long and one short="61". This is the O2 sensor. There are sites/threads with the CEL codes on them so you can distinguish which code is for what designated error. Hope this helps.
Steve
gtec8285
Jul 21, 2008 01:04 PM
rch022
Jan 5, 2008 04:52 AM
disposable
Aug 14, 2005 03:43 AM
beeroh
Sep 24, 2004 08:16 AM
BlkGSR
Jun 18, 2003 07:11 PM
