Crower or Skunk2?
Old Apr 13, 2004 | 01:46 PM
98TypeSH's Avatar
Default Crower or Skunk2?
which is the best bang for the buck in terms of vavletrain and cams. ive heard mixed opnions and was just wondering before i commited to anything.
Old Apr 13, 2004 | 04:35 PM
Revi's Avatar
Default Re: Crower or Skunk2? (98TypeSH)
https://honda-tech.com/zerothread?id=577158
Old Apr 13, 2004 | 05:56 PM
98TypeSH's Avatar
Default Re: Crower or Skunk2? (Revi-Ra)
Thanks for the link. They never really came to a conclusion. is it just preference or is one built stronger than the other. certain shops recommend certain products. Anyone have any available dyno sheets for crower stage 2 or skunk stange 2 cams?? im also doing entire vavletrain so any help there would also be much appriciated. thanks in advance.
Old Apr 13, 2004 | 11:06 PM
dawalude's Avatar
the skunk2 cams have a higher lift than the crowers in the same stage. however, with both cams if you are going stage 2 or above, you won't notice much difference unless you up the compresssion. stage 2+ cams really shine with upped compression. its a matter of preference, in a sense that, it depends on what your goals are. both are great cams, skunk2 cams are known to be more aggressive (skunk2 stage 2 cams are equivalent to crower stage 1 cams, for example).
Old Apr 14, 2004 | 06:09 AM
SuperSlow's Avatar
Default Re: Crower or Skunk2? (dawalude)
I thought Crower 2 was equivalent to Skunk2 stage 1, and Crower 3 was more like s2s2... Maybe I should look again at the specs..
or you should.
Old Apr 14, 2004 | 06:20 AM
94vtecmn's Avatar
Default Re: Crower or Skunk2? (SuperSlow)
I have dyno'd before and after my cam upgrade. Also included in that was the change over to Type-S pistons, and .25 oversizing.
Cams = Crower Stage 2 Cams, dual springs and titanium retainers.
Pistons = Type-S .25 oversized pistons ~11:1 vs. the 10.6 stock
174.8 before cams, pistons and V-AFC
195.2 after cams, pistons, and tuned with a V-AFC
Note: You will be WAAAAAY lean without a tuning device.
Old Apr 14, 2004 | 09:28 AM
Daboi630's Avatar
Default Re: Crower or Skunk2? (94vtecmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtecmn &raquo;</TD></TR><TR><TD CLASS="quote">I have dyno'd before and after my cam upgrade. Also included in that was the change over to Type-S pistons, and .25 oversizing.
Note: You will be WAAAAAY lean without a tuning device.</TD></TR></TABLE>
the reason why i want crower stage 2
hey did you have to alter the rocker arms?
Old Apr 14, 2004 | 09:50 AM
94vtecmn's Avatar
Default Re: Crower or Skunk2? (Daboi630)
Yes, they were all modified.
Old Apr 14, 2004 | 10:09 AM
Daboi630's Avatar
cool
Old Apr 14, 2004 | 10:15 AM
dawalude's Avatar
oh yeah sorry my bad got it mixed around..skunk2 stage 1 == crower stage 2
Old Apr 14, 2004 | 11:23 AM
98TypeSH's Avatar
Thanks everyone for your input. i got 1 more question. so if i get the whole skunk2 setup should i run a p28 ECU on my H series? or should i get a p13 and get it chipped and so on.
Old Apr 14, 2004 | 11:42 AM
Daboi630's Avatar
personally i would go for hondata. but from those 2 i think you would have to go p28 chipped. dont know how a chipped p13 would be.
Old Apr 14, 2004 | 11:54 AM
98TypeSH's Avatar
Default Re: (Daboi630)
i think im gonna go for the p28 and hondata s200
Leo's 07 Honda Civic Si
Honda Civic (2006 - 2015)
35
Sep 14, 2009 08:04 PM
panda_eh2
May 1, 2008 08:16 AM
Fresno_NSX
Apr 1, 2005 09:46 PM
riceball777
Oct 19, 2003 09:53 PM
