HELLLPPPPPP!!!!!!!!!!!!!!!!!!!!!
Old Apr 11, 2004 | 04:11 PM
shadowludeJDM's Avatar
Default ECU pins diagram for Vtec
does anyone know which pin number in the ecu runs the vtec ...i wired the v-tec but don't know which pin to connect it to. i have a 95 prelude and i swap the engine from h23 to jdm h22a1 please let me know thank you.
Modified by shadowludeJDM at 9:49 PM 4/13/2004
Old Apr 11, 2004 | 05:11 PM
jdmlude_dude's Avatar
Default Re: HELLLPPPPPP!!!!!!!!!!!!!!!!!!!!! (shadowludeJDM)
A4 = Vtec Solenoid
D6 = Vtec Oil Pressure Switch
There are 2 wire tha come out of the vtec pressure switch, one is hot and goes to pin D6 and the other can just be grounded off on the motor or on the chassis
Old Apr 11, 2004 | 07:14 PM
Default Re: HELLLPPPPPP!!!!!!!!!!!!!!!!!!!!! (jdmlude_dude)
Modified by shadowludeJDM at 9:50 PM 4/13/2004
which one is A4 and D6
Old Apr 11, 2004 | 09:44 PM
if you take the ecu and look at the pins as if it were in the car, say you lay it on a table with the top facing up and you look as the pins, the "A" pin numbers will start on the very right, Example:
Top side w/ the sticker
----------------D6------------------------------------A4---
l --------------\/---- -------------- -------------------\/-- l
l l oo . . . . . . . . o ll . . . . . . . . ll oo . . . . . . . . ooo l l
l -------------------- -------------- ----------------------- l
hope that turns out right...change your post title to make that search friendly...like ecu pins diagram for vtec.
Old Apr 13, 2004 | 08:54 PM
Default ecu pins diagram for v-tec
i'm still getting a check engine lights if i put my new ecu in.... why is that? right now i'm using my stock ecu for h23 so that i can use the car. i know it will not open the v-tec but i don't get an engine check light. does anyone knows?
Old Apr 13, 2004 | 08:56 PM
on the v-tec oil pressure there r 2 wires does it matter which one goes to the ecu and which one goes ground? if so let me know which one is which?
tofastgsr
Engine Management and Tuning
Oct 26, 2012 06:11 AM
mills7x
Apr 2, 2012 11:29 AM
tgjg19
Aug 17, 2009 07:41 PM
sharkcohen
Mar 11, 2005 07:55 AM
rev-speed
Nov 17, 2003 08:05 PM
