knocking.....?
Old Apr 13, 2004 | 10:45 PM
h2point2's Avatar
Default knocking.....?
ok well i had this knock in my block and my mechanic said it was my balance shafts i was scepticle because it sounded like it was coming from the tranny side of the block. i took my balance shaft belt off and well the noise is still there. i am going to pull tranny tomorrow to see if it is my clutch or flywheel that became loose again. any other ideas, like 3 nights before that i was racing and hit 3rd gear at about 105-115 misshift of course but only for a split second did not see what my aftermarket tach read but i know it wasnt good. if i fried a bearing wouldnt it go out right there and i could hear it? this noise is almost like a T/O bearing went bad but i just had them replace it. between shifts and when revving its like a grinding/banging. and when the car warms up and is at complete idle the noise is the worst and bangs more but if i put my foot on the clutch it gets rid of the noise. think it is a clutch or flywheel, or something with crank i really need input on this thank you.
Old Apr 14, 2004 | 09:47 AM
h2point2's Avatar
Default Re: knocking.....? (h2point2)
bump
Old Apr 14, 2004 | 11:37 AM
AndyGCT's Avatar
valve adjustment...worked for me...
eg_b18c
Transmission & Drivetrain
17
Oct 31, 2018 07:24 PM
usdmed9
May 17, 2011 10:46 AM
bennjamin@ozhonda.com
Nov 30, 2005 01:35 PM
garados
Feb 3, 2003 11:08 AM
E-lude78
Mar 13, 2002 05:29 PM
