tranny HELP!!
Old Apr 14, 2004 | 07:39 PM
h2point2's Avatar
Default tranny HELP!!
ok i took the tranny mount off took the top 3 bolts out took the bottom 3 bolts out what else is there to do my tranny wont budge off the block am i missing something!
Old Apr 14, 2004 | 08:57 PM
99spanishGT
Guest
Posts: n/a
Default Re: tranny HELP!! (h2point2)
flat head.
Old Apr 14, 2004 | 10:16 PM
jdmlude_dude's Avatar
Default Re: tranny HELP!! (spanishlude)
you shouldnt have to force it. Do you ahve the rear motor mount taken off?
Old Apr 14, 2004 | 11:53 PM
h2point2's Avatar
Default Re: tranny HELP!! (jdmlude_dude)
i took the 2 bolts out of the rear motor mount that hold the tranny. i have a 90 accord with jdm h22 but same motor mounts as prelude really but i got the 2 bolts out but the tranny wont budge and it was just recently taken off for a new t/o bearing. i took the slave cylinder off but do i need to pull out the t/o handle too. this is my first tranny pull ive put it back on but never off :\
Old Apr 15, 2004 | 05:53 AM
Dont forget the bolts to the starter!
Old Apr 15, 2004 | 12:23 PM
Honda Sport's Avatar
I was stuck too. there should be 2 more bolts right next to the rear mount bracket. so you take those 3 off the rear bracket and then there should be 2 that goes from the block to the tranny. no matter what you do, DO NOT PRY THE TRANNY OFF. you'll damage something. I tried to pry through the timing flywheel hole and almost damged the timing point. it should come straight off without prying once you get all the bolts off.
Old Apr 15, 2004 | 02:01 PM
h2point2's Avatar
Default Re: (Honda Sport)
i got it off and yes there was 2 more bolts i missed i hate how those things hide. anyhow im gonna pull the clutch off later, i noticed that the bolts had wierd heads can i use just a regular socket to take em off. i think it is my clutch/flywheel making that noise cause i can move my clutch and flywheel back and forth like an inch almost....there shouldnt be any give and ive had my flywheel bolts loosen on me before.
Old Apr 15, 2004 | 05:09 PM
Default Re: (h2point2)
put a little thread lock on those bolts! 1/2" impact works good too!
Old Apr 15, 2004 | 07:07 PM
h2point2's Avatar
Default Re: (jdmlude_dude)
well 2nd time its happened all bolts except 1 were finger loose on my flywheel happened with stock setup and my new action 6puck with high pressure plate and my 12lb flywheel just bought it 4 months ago now i need another one :D sucks.
Old Apr 16, 2004 | 12:17 PM
ahh...well at least you found them pretty quickly. took me a like 10 mins to find them. you dont' need a special socket to take off the bolts, they're 12 point so just use 12 point sockets on them. I know they look weird don't they? never really see 12 points bolts too often. good luck.
averyvm
Aug 7, 2007 09:57 PM
Alpinestar03
May 11, 2007 04:26 PM
cincispeedemon
Oct 10, 2004 02:50 PM
tallblondkid
Aug 11, 2004 01:32 AM
Turbohatch
Oct 26, 2001 12:25 PM
