Engine stand bolts.
Old Aug 23, 2004 | 06:11 PM
Matgallis's Avatar
Default Engine stand bolts.
I've read that the transmission bolts will work with perfect length. Well i don't have any spare transmission bolts. I need to know the correct thread size and bolt length.
It appears that there are one hole on both sides that are larger? Look like 14mm?
Old Aug 23, 2004 | 06:47 PM
Matgallis's Avatar
Default Re: Engine stand bolts. (Matgallis)
come on home depot closes sooN!
Old Aug 23, 2004 | 07:35 PM
Matgallis's Avatar
ok home depot's bolt supply sucks ***
Old Aug 23, 2004 | 08:12 PM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">ok home depot's bolt supply sucks ***</TD></TR></TABLE>
i agree with that totally they have s hitty selection of metric bolts and the ones they ahve are too short anyway.
Old Aug 23, 2004 | 11:01 PM
noble4ws's Avatar
just take a tranny bolt with you to compare the threads
Old Aug 23, 2004 | 11:30 PM
SKDRCR's Avatar
Default Re: (noble4ws)
only one of the transmission bolts will be long enough to work
that's the one going through the starter to the tranny.
take that bolt with you to the hardware store and find a nut that will
screw onto that bolt. once you find a nut, look for another bolt
that will match up to that nut and is just as long as your tranny bolt.
the home depot in my area didn't have the right size, but ace hardware did.
it's a metric fine thread bolt, i can tell you that for sure
Old Aug 24, 2004 | 02:30 PM
v4lu3s's Avatar
RTFM
usually honda bolts have a pitch of 1.25, the hard part is always fiunding the right length not the right diameter...the big hardware stores suck they usually only carry at most a 60mm bolt which is about 2.38 inchs long
Old Aug 25, 2004 | 02:36 PM
Matgallis's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">usually honda bolts have a pitch of 1.25, the hard part is always fiunding the right length not the right diameter...the big hardware stores suck they usually only carry at most a 60mm bolt which is about 2.38 inchs long</TD></TR></TABLE>hmm yea 2.38 inches is a few too short... i might try taking that one bolt out when I have time thanks for the help
bdubnyc
13
May 13, 2008 10:16 AM
tpot90
Apr 5, 2008 09:46 AM
KFMRC
Honda S2000
May 18, 2006 11:08 AM
explictness
12
Dec 26, 2005 05:14 PM
BLUE EH3
13
Jun 6, 2005 02:04 PM
