mods for the dyno
Old Aug 22, 2004 | 02:02 PM
5thGenBen's Avatar
Default mods for the dyno
i have a 98 base and ive added i/h/e, vafc, stage 1 exedy clutch, and a jun flywheel. i was wondering what other mods would help before i go to the dyno to tune the vafc, would a fpr or cam gears be of any help? and before i go, i plan on redoing the collector on my dc header to 2.5 inches and adding a hi flow cat but is there anything else that would help?
Old Aug 22, 2004 | 02:45 PM
DarkBB4's Avatar
Default Re: mods for the dyno (5thGenBen)
wow this is crazy,,... i have the exact same set up as u... i /h/e exedy clutch . jun flywheellll (1995 prelude vtec) and my vafc is in the mail
gl with the dyno
Old Aug 23, 2004 | 11:33 AM
jdm_loser's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thGenBen &raquo;</TD></TR><TR><TD CLASS="quote">i have a 98 base and ive added i/h/e, vafc, stage 1 exedy clutch, and a jun flywheel. i was wondering what other mods would help before i go to the dyno to tune the vafc, would a fpr or cam gears be of any help? and before i go, i plan on redoing the collector on my dc header to 2.5 inches and adding a hi flow cat but is there anything else that would help?</TD></TR></TABLE>
ya the fpr and the cam gears would help a lot in tuning
Old Aug 23, 2004 | 11:45 AM
EuRoBrO's Avatar
Default Re: mods for the dyno (jdm_loser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_loser &raquo;</TD></TR><TR><TD CLASS="quote">
ya the fpr and the cam gears would help a lot in tuning</TD></TR></TABLE>
Even with stock Cams?
Old Aug 23, 2004 | 12:02 PM
DIE DIE's Avatar
let us know what you put down! goodluck!
Old Aug 23, 2004 | 12:10 PM
94vtecmn's Avatar
If your valve cover is cut to adjust the adjustable cam gears, and your using stock cams, then you might get a little. As for the FPR, not needed with stock cams. Actually, tuning with what you have there, there is not a whole lot to be gained with a VAFC, but you may gain a 3-4 whp.
In all reality, with what you have done, the stock computer will compensate just fine, a little rich, but just fine. Get some stage 2 crowers, or some other stage 2 cams, and then yes, you'll need to get it tuned.
Old Aug 23, 2004 | 02:59 PM
Behan's Avatar
Default Re: mods for the dyno (94vtecmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94vtecmn &raquo;</TD></TR><TR><TD CLASS="quote"> Actually, tuning with what you have there, there is not a whole lot to be gained with a VAFC, but you may gain a 3-4 whp.
Actually, depending on tuner they should be able to net abit more by leaning it out. With I/H/E and vafc tuned i gained 6 peak whp and the tuner wasn't very proficient.
you should be able to get your moneys worth out of the vafc. 5-8 whp for 300.00 isn't too shabby.
Old Aug 24, 2004 | 07:59 AM
5thGenBen's Avatar
Default Re: mods for the dyno (Behan)
thanks for the advice. hopefully ill get to a dyno in the next month. it seems like a long time until you realize the nearest dyno is 4 hours away.
Old Aug 24, 2004 | 07:45 PM
yeahdudebrown's Avatar
i was wondering the same thing, i have i/h/e and a jdm h22, would cam gears and a fpr help if i got a vafc
Old Aug 24, 2004 | 07:57 PM
PreludeRacer023's Avatar
Default Re: mods for the dyno (yeahdudebrown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeahdudebrown &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering the same thing, i have i/h/e and a jdm h22, would cam gears and a fpr help if i got a vafc</TD></TR></TABLE>
you guys all thinking cam gears wont help with a stock motor...buahhahahah...think what you want, and people wonder how i obtained 196whp on a dyno with my JDM h22 i/h/e/cam gears/ecu..this was after i got rid of my vafc....and also my fpr was helpful in running feul with my new ecu which is a GSR mugen p28..and for the record it was 13.5 to 13.7 all through the revs on a wideband
Old Aug 24, 2004 | 08:05 PM
DarkBB4's Avatar
Default Re: mods for the dyno (PreludeRacer023)
how mcuh is a dyno usually per hour or for how long it would be to tune my vafc
(sorry for jacking)
tomlinson619
37
Oct 9, 2006 01:41 PM
ninjastance_batmang
17
Nov 8, 2004 12:59 PM
Eclpze97
Jul 5, 2004 08:26 PM
atmo_monster
Jun 21, 2004 02:50 PM
StinkyTofu
Feb 25, 2002 02:40 PM
