TPS sensor question
Old Aug 24, 2004 | 04:35 PM
hOndafienD 04's Avatar
Default TPS sensor question
so i replaced my throttle body today, and installed the old sensor...and noticed it had an adjustment...will this affect performance in any way if its not in the right place? and also how would i kno when its at the right point? thanx
Old Aug 24, 2004 | 05:09 PM
3gLudeH22A's Avatar
Default Re: TPS sensor question (hOndafienD 04)
yes it will effect performance if its not set right....get a volt meter and set it to 4.5v open.
Old Aug 24, 2004 | 06:26 PM
aiight what wire should i have a voltage signal at? theres 3 wires.
Old Aug 24, 2004 | 06:27 PM
caLiH22A's Avatar
Default Re: (hOndafienD 04)
how did you remove your old TPS? I've looked at mine before when I took off my TB and the TPS has two allen type of screws.
Old Aug 24, 2004 | 07:17 PM
with f*cking pliers...it turns out like a normal screw but be advised dat dey are a biitch! have fun lol
Old Aug 24, 2004 | 08:33 PM
thehondaguru's Avatar
or take a dremal and turn them bitches into a flat head screw!
Old Aug 25, 2004 | 07:18 PM
i set my tps to like .6 ohms of resistance at idle and 4.5 ohms of resistance @ WOT......is dat how its suppossed to be set....it's pulling real strong so i guess its good..
Old Aug 26, 2004 | 12:51 AM
Eddiebx's Avatar
should be set to about .5 volts at closed, and 4.5 at WOT. measure the voltage of the middle wire, with the tps plugged in
PHILLIPDEEZ
Jan 24, 2005 06:05 PM
wompwomp61
Oct 24, 2004 03:46 PM
kholmes
Oct 12, 2004 06:59 PM
CRX A4
Jun 14, 2003 09:43 AM
boosted hybrid
Apr 1, 2002 06:20 AM
