vafc and vtec problem(searched)
Old Aug 19, 2004 | 07:11 PM
5thGenBen's Avatar
Default vafc and vtec problem(searched)
i just installed my vafc and my vtec isnt engaging so i pulled the ecu back out and the connections to/from the vtec sensor seem fine...i really dont know what else to check. also my tach in the dash is about 1000rpm higher at midrange (4000 rpm on the dash tach and 3000 rpm on the vafc tach). but i've read that honda tach are off and that some apexi electronics give faulty rpms for some reason. any help would be greatly apprieciated
Old Aug 19, 2004 | 07:26 PM
Shakes's Avatar
space cadet
Default Re: vafc and vtec problem(searched) (5thGenBen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thGenBen &raquo;</TD></TR><TR><TD CLASS="quote">i just installed my vafc and my vtec isnt engaging so i pulled the ecu back out and the connections to/from the vtec sensor seem fine...i really dont know what else to check. also my tach in the dash is about 1000rpm higher at midrange (4000 rpm on the dash tach and 3000 rpm on the vafc tach). but i've read that honda tach are off and that some apexi electronics give faulty rpms for some reason. any help would be greatly apprieciated</TD></TR></TABLE>
you wired it incorrectly somewhere.
1 - how did you make the connections? solder, etc..
2 - how are your ground wired placed? one of them (brown i believe) needs to be closer to the ECU then black.
the tach should be about 400 RPM above the VAFC tach. trust the VAFC once everything gets working properly. until then go by the in dash tach.
Old Aug 19, 2004 | 07:57 PM
5thGenBen's Avatar
Default Re: vafc and vtec problem(searched) (Shakes)
thanks for the reply. tomorrow im going to solder all the connections. today i used male/female connectors, i knew i couldnt trust them. i did place the brown closer to the ecu but the gap between the brown and black wires from the vafc are only about an inch apart, will that make a difference? also, i just hooked everything back up and the vafc rpm readout was at zero so it was definitely the connection. thanks for the help
Old Aug 19, 2004 | 08:36 PM
Mario.'s Avatar
Did you get the correct sensors, cylinder number, and throttle arrow setup correctly?
Old Aug 19, 2004 | 08:44 PM
5thGenBen's Avatar
Default Re: vafc and vtec problem(searched) (Mario BA4)
i did 6 in, 6 out, 4 cyl, and i had the arrow pointing up and to the right. the only one im unsure of is the throttle arrow.
Old Aug 19, 2004 | 09:04 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thGenBen &raquo;</TD></TR><TR><TD CLASS="quote">i did 6 in, 6 out, 4 cyl, and i had the arrow pointing up and to the right. the only one im unsure of is the throttle arrow.</TD></TR></TABLE>
i dont think the throttle arrow will affect anything car wise. but i could be wrong about that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thGenBen &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the reply. tomorrow im going to solder all the connections. today i used male/female connectors, i knew i couldnt trust them. i did place the brown closer to the ecu but the gap between the brown and black wires from the vafc are only about an inch apart, will that make a difference? also, i just hooked everything back up and the vafc rpm readout was at zero so it was definitely the connection. thanks for the help </TD></TR></TABLE>
whenever possible never use connectors. they add a load to the system and do not pass the signal like a proper solder job will. dont forget to heat shrink them as well.
an inch apart is fine.
Old Aug 20, 2004 | 06:53 AM
5thGenBen's Avatar
thanks for the .02 $
RAB
Dec 8, 2002 09:57 PM
mntdewred
Jul 26, 2002 09:28 AM
Chugger
Apr 27, 2002 05:50 PM
4doorH22
Jan 4, 2002 11:01 AM
