fuel filter
Old Aug 23, 2004 | 08:23 PM
bseries_beast's Avatar
Default fuel filter
Does any one know an easy way to take the fuel filter off? I tried changing it today and there is like barely any room to loosen the bottom bolt.
Old Aug 23, 2004 | 08:31 PM
equinox's Avatar
Default Re: fuel filter (krazie4vtec)
There really is no room to take off the bottom bolt for the filter when I tried to do it myself, so I had my friend do it since he had a lift I'm sure you will be able to take it off eventually...
Sorry I'm not much help
Old Aug 23, 2004 | 10:34 PM
Wiseguy619's Avatar
It is not too much fun to get at. I had a lift also to change mine.
Old Aug 23, 2004 | 10:43 PM
Behan's Avatar
Default Re: fuel filter (ProjectPenny)
Is the fuel filter setup on the 5th gen different then the 4th gen?
I have changed mine several times in the driveway with no problem, 5 min job.
Just curious
edit: N/M i went and looked for myself. Damn that sucks, here is the 4th gens set up lines 3 and 12
5th gens ( for the archive)
Old Aug 23, 2004 | 10:47 PM
Wiseguy619's Avatar
I don't exactly know if the location is different for the SH than the base model, but mine is on the left side, inbetween the IM and the shock tower, right in the middle of a whole bunch of **** that is in the way. I am sure it is possible to take out w/o a lift, but I work at a place that has lifts so I did it that way. Nonetheless, it was a lot easier w/ a lift.
Old Aug 24, 2004 | 05:40 AM
MechEng's Avatar
No major clearance issues on the 4th gen.. but the fuel line bolts were as tight as a young virgin
I needed a insanely long breaker bar to loosen them
Old Aug 24, 2004 | 06:19 AM
94vtecmn's Avatar
Default Re: fuel filter (MechEng)
They come right off with a LINE wrench, an open end box ended wrench, that has two extra sides to it. Basically a 5 sided box end wrench. Somewhat of a specialty tool, but most any auto parts store should have one.
Old Aug 24, 2004 | 07:58 AM
98TypeSH's Avatar
Default Re: fuel filter (94vtecmn)
I wouldent be supprized if it was even harder to get to on an SH. Luckly i havent had to go after that thing yet. Hey Behan, check out where the oil filter is on an SH, lol. There is no room for anything, the atts and lines are all over the freakin place.
Squad Walker
Jun 18, 2007 08:07 PM
A Tribe Called Honda
Mar 30, 2007 05:28 PM
kornerk12
Oct 25, 2006 09:46 PM
kornerk12
Dec 23, 2005 01:27 PM
speedaccordinly
Apr 25, 2003 03:39 PM
