Constant 12 v source?
Old Aug 20, 2004 | 04:01 PM
4thgenlude's Avatar
Default Constant 12 v source?
I got a power door lock kit, for my 92 prelude S, and it says i need a 12 volt wire, preferably from the fuse box.
my question is, which wire should I use? i know i should get a wire tester but im kinda broke right now and I would rather not get one unless absolutely necesary
thanx for your help
-Charlie
Old Aug 20, 2004 | 04:14 PM
foshizllmynizl's Avatar
Default Re: Constant 12 v source? (4thgenlude)
check the helms if you have one ... dont bother asking for the link to one on HT auto point deductions ... i wonder if its the same wiring for 5th and 4th gens ... let me check mine ... untill then ask someone witha 4th gen helms to help u out ... pece
Old Aug 21, 2004 | 08:38 AM
4thgenlude's Avatar
Default Re: Constant 12 v source? (foshizllmynizl)
thanks
anyone know for sure?
Old Aug 21, 2004 | 01:19 PM
eLUDEnu
Guest
Posts: n/a
use the 12 volt power source to your headunit
Old Aug 24, 2004 | 09:01 AM
4thgenlude's Avatar
Default Re: Constant 12 v source? (eLUDEnu)
thanks, but where is that?
Old Aug 24, 2004 | 09:50 AM
Qveon's Avatar
use the 14 or 12 gauge WHITE wire running to your igintion switch located close to the steering column. Ignition is black/yellow if you need that too. located in the same place.
Old Aug 24, 2004 | 10:00 AM
4thgenlude's Avatar
Default Re: Constant 12 v source? (Qveon)
thanks!!!
Old Aug 24, 2004 | 12:50 PM
4thgenlude's Avatar
is there one for the cigarette lighter?
Because i never use it, so I could just use the 12v wire to the cig lighter if there is one.
thanks
Old Aug 24, 2004 | 04:21 PM
optikal_blitz's Avatar
don't use that one..the voltage is only available when the ignition is on.
Old Aug 24, 2004 | 04:42 PM
4thgenlude's Avatar
Default Re: Constant 12 v source? (NatakuBlitz)
what should I use then?
I dont wnat to mess anything up that ill need
Old Aug 24, 2004 | 05:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Qveon &raquo;</TD></TR><TR><TD CLASS="quote">use the 14 or 12 gauge WHITE wire running to your igintion switch located close to the steering column. Ignition is black/yellow if you need that too. located in the same place.</TD></TR></TABLE>
there ya go. the ignition power wire is always hot.
there's a memory wire ( i think its yellow ) that goes to the headunit.. however, i don't think its 12v.. you could try tapping that..i know it gets constant voltage but how much..don't know. Whichever wire you splice into..be sure to do it properly with solder or a real good crimp set + electrical wire.
Old Aug 26, 2004 | 02:08 PM
4thgenlude's Avatar
thanks!!! , and yeah its the yellow one
for anyone else that needs a 12 volt source at all times
Modified by 4thgenlude at 5:35 PM 8/26/2004
Old Aug 26, 2004 | 08:03 PM
4thgenlude's Avatar
it didnt work. grrrrrrr
it gets constant voltage but its not a 12 v, i think
Old Aug 26, 2004 | 08:19 PM
google search a 4th gen wiring diagram and find the constant hot wire for the ignition. that's your best bet.
Old Aug 26, 2004 | 09:14 PM
BrokeLude's Avatar
and buy a multimeter. is $10 too much to ask to not screw up your car?
LazyAzn
10
Dec 22, 2010 10:58 PM
98civhatch
Jul 5, 2009 05:58 PM
Strikerrr
Oct 6, 2005 04:08 PM
Avian
Jan 4, 2002 06:27 PM
MestizoRacer310
Dec 12, 2001 10:08 AM
