found the CLUTCH problem
Old Nov 21, 2004 | 08:16 PM
MyVtec8yourV8's Avatar
Default found the CLUTCH problem
Well I pulled the tranny and the clutch was fine as well as the pressure plate and bearing. BUT here is the problem.
SOOO can i use the old bolts and what could have caused this? I torqued them down to 81lbs. I did forget to use LOC-TITE but could that happen so quickly? only 200 miles? The crank bolt holes look ok not stripped or anything.
Old Nov 21, 2004 | 08:27 PM
hOndafienD 04's Avatar
wow! wtf?! i guess you shoulda used loctite...thats crazy
Old Nov 21, 2004 | 09:09 PM
PrettyLude's Avatar
dang
Old Nov 21, 2004 | 09:21 PM
SKDRCR's Avatar
Default Re: (PrettyLude)
I didn't use locktite because the Helms did not say to.
Hopefully they will hold up (6k on clutch so far)
Old Nov 21, 2004 | 09:24 PM
Default Re: (SKDRCR)
yeh usually it should hold up...what did you torque the bolts to? at work we just do it with the air gun...those suckers aint never coming off
Old Nov 21, 2004 | 09:33 PM
SKDRCR's Avatar
Default Re: (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">what did you torque the bolts to? </TD></TR></TABLE>
As tight as I humanly could.
Old Nov 21, 2004 | 10:28 PM
hoehouseworker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
As tight as I humanly could.</TD></TR></TABLE>
So not very tight huh?
Old Nov 21, 2004 | 10:42 PM
aboh6leenz's Avatar
Default Re: (hoehouseworker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hoehouseworker &raquo;</TD></TR><TR><TD CLASS="quote">So not very tight huh? </TD></TR></TABLE>
hahahahaha
Old Nov 22, 2004 | 12:07 AM
94_HATCH's Avatar
Damn thats crazy. What symptons were you having?
Old Nov 22, 2004 | 03:09 AM
Default Re: (94_HATCH)
My symptoms are here....
https://honda-tech.com/zerothread?id=1060391
I torked them to 81 lbs and they came loose im worried my crank is bad.. i looked at the threads and there fine... and this is only the second time the fly wheel bolts were torked down the first time being at the factory. So i hope its not stripped.
Old Nov 22, 2004 | 04:05 AM
jackstands's Avatar
Default Re: (MyVtec8yourV8)
Inspect it carefully for stripped threads, if everything is cool, don't sweat it. That happened to me about 2.5 months ago except 6 of 8 came free. You can't use your clutch/flywheel again so that sucks. I'd imagine the back of your disc is nicked up, and the disc hub probably rubbed up on your pressure plate, and the flywheel is probably scarred up from the bolts back out. Oh, and if you need another stock flywheel, you can have mine, just pay for shipping.
Old Nov 22, 2004 | 12:24 PM
thats good! the only things i torque are any parts with bearings in them....crank, cam, etc.....everything else i just tighten all the way... im scared of **** coming loose.
Old Nov 22, 2004 | 04:09 PM
PrettyLude's Avatar
loctite is ur friend
Old Nov 22, 2004 | 04:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">loctite is ur friend</TD></TR></TABLE>
i've learned to use it....
Old Nov 22, 2004 | 04:46 PM
Default Re:
I got new bolts today and threaded one in all the way each hole by hand to be sure i didnt mess the crank threads.. it went in all the way smoothly in all the holes so im pritty sure the crank is ok. I think what may have made them vibrate out is my crank puly it is chipped to all hell. So ill get a new one well a stock new one... and have the flywheel checked and trued to be sure there is no unneeded virbation. I will put it all back together on friday at the hobby shop because the hobby shop is closed this week tues-thursday. After that i think im going to make an appointment with Wayne for like monday or tuesday befor i go to Desert Talon.
But over all im glad it was a easy fix.. but good lord those bolts are expensive. $9 just for 2 of them... BETTER than a new clutch or tranny i sapose..
Old Nov 22, 2004 | 05:29 PM
jackstands's Avatar
Default Re: Re: (MyVtec8yourV8)
Glad to hear the clutch and flywheel were salvageable. USE RED LOCTITE. I loctited the **** out of every bolt. FYI: According to Helms, you have to get new rear motor mount bolts.
Old Nov 22, 2004 | 05:45 PM
Default Re: Re: (jackstands)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jackstands &raquo;</TD></TR><TR><TD CLASS="quote">Glad to hear the clutch and flywheel were salvageable. USE RED LOCTITE. I loctited the **** out of every bolt. FYI: According to Helms, you have to get new rear motor mount bolts.</TD></TR></TABLE>
Umm are you saying that sarcasticly? Meaning helms says get new bolts but ya dont need them?
Old Nov 22, 2004 | 05:47 PM
and tighten them all the way as much as you can.....**** torqueing them...just dont snap them lol
Old Nov 22, 2004 | 09:02 PM
PrecisionH23a's Avatar
Default Re: found the CLUTCH problem (MyVtec8yourV8)
Just in case anyone was wondering... I built jeff's shortblock. When I saw the crank pulley I immediately told him not to run it. The reason the flywheel bolts backed out is because of the SEVERLY damaged crank pulley he used. The harmonic vibrations that the pulley sent through the rotating assembly in my opinion could have caused the flywheel bolts to back out. I wish I had a picture of the pulley... it was REALLY bad. That, or they were not properly torqued/installed.
Oh well. You live and learn. I recommend always using loctite on the flywheel bolts as well as triple checking the torques on every bolt.
Old Nov 23, 2004 | 05:29 PM
prelittlelude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyVtec8yourV8 &raquo;</TD></TR><TR><TD CLASS="quote">Well I pulled the tranny and the clutch was fine as well as the pressure plate and bearing. BUT here is the problem.
SOOO can i use the old bolts and what could have caused this? I torqued them down to 81lbs. I did forget to use LOC-TITE but could that happen so quickly? only 200 miles? The crank bolt holes look ok not stripped or anything.</TD></TR></TABLE>
wo someones got some secondorder bottom end vibrations.. isn't this a common problem on some 5th gens,, i think i went alittle tighter than 81 ft/lbs ..
replae the bolts you will never get a grip on those to re tighten, and if they are bent or the threads are chewed you don't want to screw that into your crank
edit: just read anthonys post, .. harmonic balancer is important, i wouldn't runa fucked up one
Old Nov 23, 2004 | 05:35 PM
Default Re: found the CLUTCH problem (prelittlelude)
Yea i bought new bolts.. there like 5 bucks a peice..lol but here is a pict of my fucked up pully that Anthony was talking about. Im putting a new pully and having the fly wheel resurfaced and trued.
Old Nov 23, 2004 | 05:40 PM
yeah.... so im gonna go ahead and say that pulley is probably not the most balanced thing anymore..
Old Nov 24, 2004 | 05:03 AM
BoostedH23Accord's Avatar
Man!!!! That thing looks like you got Gremlins under your hood.
Old Nov 24, 2004 | 06:09 AM
Default Re: found the CLUTCH problem (BoostedH23Accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedH23Accord &raquo;</TD></TR><TR><TD CLASS="quote">Man!!!! That thing looks like you got Gremlins under your hood.</TD></TR></TABLE>
If you got a h22 in an accord you will most likly agree its a tight fit.. i chipped it getting it in the car the first time wish all the belts on.. now if i got to pull the motor i take the pully off.
Old Nov 26, 2004 | 09:21 AM
matix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyVtec8yourV8 &raquo;</TD></TR><TR><TD CLASS="quote">If you got a h22 in an accord you will most likly agree its a tight fit.. i chipped it getting it in the car the first time wish all the belts on.. now if i got to pull the motor i take the pully off.</TD></TR></TABLE>
You dont have to take the motor out to take the pulley off on an accord. I just did my timing belt on my h22 accord and all you have to do it lower the drivers side of the motor. So just take that mount off.
