timing
Old Nov 19, 2004 | 01:05 PM
Monkey Fing a Coconut's Avatar
Default timing
does anyone have a write-up or can explain how to adjust timing on an h22a, nothing came up in search and the helms doesnt say anything that i could find
thanks
Old Nov 19, 2004 | 02:54 PM
homesauce's Avatar
Default Re: timing (twistedbydezign)
Im gonna assume you mean ignition timing. rotate your distributor. If you search on it, there are a lot of posts about it. I forget which way is advance, which way is retard.
Old Nov 19, 2004 | 03:56 PM
Default Re: timing (homesauce)
i got that part, but do u have to take off the bottom timing belt cover or can u use the lines on the flywheel with a timing light...???
Old Nov 19, 2004 | 04:00 PM
homesauce's Avatar
A timing light should be all you need. You shoudn't need to take off a timing belt cover...
Old Nov 19, 2004 | 11:57 PM
but where do i shine the timing light...the little hole where i can see the flywheel or...???
Old Nov 20, 2004 | 03:07 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">but where do i shine the timing light...the little hole where i can see the flywheel or...???</TD></TR></TABLE>
Yes, It's all in the Helms. Go the the electrical section and read the
table of contents,you should be able to find exact instrutions on how to do it
Old Nov 20, 2004 | 11:01 AM
Default Re: timing (SKDRCR)
awww...there it is...2 pages out of 1600 can be hard to miss....thanks
it doesnt say though, do you rotate the dist to adj timing while the car is on or do u turn it off, adj, then turn it back on and check, and then turn it off and adj more if needed???
Old Nov 20, 2004 | 11:05 AM
Hawkze_2.3's Avatar
Adjust it while it's on, but make sure you jump the service connector so the ECU doesn't correct what you change.
Old Nov 20, 2004 | 12:42 PM
md23vtec's Avatar
Default Re: timing (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Adjust it while it's on, but make sure you jump the service connector so the ECU doesn't correct what you change.</TD></TR></TABLE>
Also make sure the car is at N O T normal operating temp.
Old Nov 20, 2004 | 12:50 PM
Hawkze_2.3's Avatar
Default Re: timing (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">
Also make sure the car is at N O T normal operating temp. </TD></TR></TABLE>
Why?.............................................. ..........&lt;----best post ever!
Old Nov 20, 2004 | 12:53 PM
md23vtec's Avatar
Why?.............................................. ..........&lt;----best post ever!</TD></TR></TABLE>
Umm I dont get what ur sayin? I doesnt seem to know that much so I could see him tryin to adjust timing with it stone cold instead of at N O T.
Jsarv
Engine Management and Tuning
Apr 1, 2012 01:48 PM
mortificationrock
Jul 15, 2007 10:59 AM
dr_latino999
Dec 2, 2004 09:55 PM
speedaccordinly24
Apr 21, 2003 08:10 AM
