Idling problems...with shaking engine
Old Nov 18, 2004 | 06:30 PM
951dc5's Avatar
Default Idling problems...with shaking engine
hey does anyone knows why i get this idling problem and the engine starts to shake?? I notice my valves are tapping louder and louder. Is that the reason my car is idling and is adjustin valves different becuz it's a vtec? Thanks
Old Nov 18, 2004 | 06:32 PM
hOndafienD 04's Avatar
yeah you might need a valve adjustment, and it could also be mis firing...check engine light on? pull out the valve cover and check for play in the rocker arms. and get the valves adjusted anyways.
Old Nov 18, 2004 | 06:40 PM
951dc5's Avatar
Default Re: (hOndafienD 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote"> check for play in the rocker arms.</TD></TR></TABLE>
I have no idea is that...
I had no engine light on..so if valve clearance are off it means could be mis firing?? thanks
Old Nov 18, 2004 | 06:45 PM
Hawkze_2.3's Avatar
Default Re: (Prelude951)
Start by doing a valve adjustment. Read this link https://honda-tech.com/zerothread?id=618786and do it yourself or take it to shop and have them do it. That should be your first step.
VTEC doesn't do anything until you rev the engine much higher...
Old Nov 18, 2004 | 06:56 PM
951dc5's Avatar
Default Re: (Hawkze_2.3)
Thanks man hope that'll do it..
criticalperformancejc
Honda Civic (2001 - 2005)
Mar 8, 2011 07:20 PM
Crx_Civic
Nov 2, 2007 10:06 AM
roberts
10
Jun 28, 2006 02:42 PM
kornerk12
Dec 18, 2005 03:27 PM
Elvis1977
Oct 22, 2003 08:05 AM
