lude nitrous
Old Nov 16, 2004 | 03:43 PM
honda1992si's Avatar
Default lude nitrous
im thinkin of runnin nitrous in my car.....what do u guys think is the right shot to run without blowing my motor.... i have an h23 ....
i was thinking just a 50 shot but i wanted to see what other people had for opinions.
Old Nov 16, 2004 | 05:56 PM
safe driver's Avatar
Default Re: lude nitrous (19lude92)
look into a wet-shot system. either way you'll need some way of retarding your ignition.
Old Nov 16, 2004 | 06:56 PM
PretecSH's Avatar
Default Re: lude nitrous (safe driver)
ah geez.
ok to be totally safe....
NX wet kit. ZEX is safer but NX gives wheel HP of what it says.
RPM window switch (turns off NX solenoids over a certain RPM, so that if you mis shift or something you dont have NX to do more damage)
Retard the ignition (buy ignition like mallory hyfire)
Buy colder spark plugs
buy a wide open throttle switch if the kit doesnt have one (goes behind the acc. pedal, you prob. know all this)
hope this helps.
Old Nov 16, 2004 | 07:29 PM
PriMaTe's Avatar
Default Re: lude nitrous (PretecSH)
I thought wet kits aren't good for fuel injected cars due to possible puddling in the intake manifold or something like that? is this true?
Old Nov 16, 2004 | 07:51 PM
Shakes's Avatar
space cadet
Default Re: lude nitrous (PriMaTe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PriMaTe &raquo;</TD></TR><TR><TD CLASS="quote">I thought wet kits aren't good for fuel injected cars due to possible puddling in the intake manifold or something like that? is this true?</TD></TR></TABLE>
wet kits are safer then dry. if its jetted properly then there will be no puddling.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PretecSH &raquo;</TD></TR><TR><TD CLASS="quote">ah geez.
hope this helps.
for a 50 shot you do not need to retard timing. just get one step colder plugs and you will be fine.
also do NOT buy the mallory ignition. its fine for low reving V8's but over 6,000 RPM it sucks *****. if you dont believe me just check my dyno, or anyones dyno that has one. misfires out the ***.
the WOT switch can go behind the gas pedal or or in the engine bay at the TB.
for an H23 my reccomendation would be a ZEX wet 55 shot. it will require the least ammount of support mods and you should be able to run that all day long.
just do a compression test before you get into it.
Old Nov 17, 2004 | 05:55 AM
darkd1gt's Avatar
Default Re: lude nitrous (Shakes)
do not spray you motor unless its ready to go, it has not that high compression and u will prob spin a rod bearing like me and be waitin for a h22a swap
BIG T
Feb 26, 2008 12:45 PM
jnasty
Jan 28, 2007 06:03 PM
Slvr_CRX
Feb 21, 2005 10:00 AM
ham
Jun 18, 2004 09:22 PM
MikeMAN
Aug 21, 2002 02:34 PM
