Traction problem
Old Nov 19, 2004 | 10:13 PM
h22a3prelude's Avatar
Default Traction problem
I am getting some terrible wheel hop off the line lately. I am using a generic front strut bar, no LSD, H22vtec 5spd. Kumho ecsta supra 17s over rotas. Any help would be great. What is the problem? What can I do to fix?
Thanks all
Modified by h22a3prelude at 4:54 PM 11/20/2004
Old Nov 19, 2004 | 10:42 PM
homesauce's Avatar
Default Re: Traction problem (h22a3prelude)
Get a rear wheel drive car?
Old Nov 19, 2004 | 10:46 PM
Default Re: Traction problem (homesauce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce &raquo;</TD></TR><TR><TD CLASS="quote">Get a rear wheel drive car? </TD></TR></TABLE>
VERY FUNNY!!
Serious help and advise only please.
Thank you
Old Nov 20, 2004 | 12:39 AM
UA6 BALLER STATUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22a3prelude &raquo;</TD></TR><TR><TD CLASS="quote">I am gettin some terrible wheel hop off the line lately. I am using a front strut bar, no LSD, H22vtec 5spd. Kumho ecsta supra 17s over rodas. Any hel pwould be great. What is the problem? What can I do to fix?
Thanks</TD></TR></TABLE>
A front strut bar isn't going to get you any traction. and I think you mean Rotas not rodas. What RPMs are you lanching it at?
Old Nov 20, 2004 | 05:09 AM
Hawkze_2.3's Avatar
Traction bars (when they finally come out), and motor mount inserts.
Old Nov 20, 2004 | 06:33 AM
Slatelude's Avatar
Default Re: Traction problem (Hawkze_2.3)
I remember some company that makes a "special" bushing for some of the front control arms (4th gen.) that virtually eliminates wheel hop?!?!?! If anyone knows what I'm talking about, please elaborate.
K
Old Nov 20, 2004 | 06:58 AM
SuperSlow's Avatar
Default Re: Traction problem (Slatelude)
Probably not. But you should get the poly inserts for your motor mounts. they will help a bit, and then whenever LCON or Anthony get their traction bars out, that will take care of the rest.
Old Nov 20, 2004 | 11:23 AM
jackstands's Avatar
Default Re: Traction problem (SuperSlow)
All those ideas are valid, but a pain in the ***. Check out your strut rod bushings, they're the bushing in the front crossmember. They hold the radius rod which is bolted to the LCA reducing/preventing the tires from sliding under load.
Old Nov 20, 2004 | 12:07 PM
matix's Avatar
Default Re: Traction problem (jackstands)
I have a bad wheel hop problem too. I have motor mount inserts so my motor does not move at all. I have lsd with falken azenis tires. When i do burnouts i have to let off sometimes bc it gets so bad that my axles feel like their gonna break. I think my ball joints split letting out the grease a while back when i changed a broken axle. Could that be causing this bad wheel hop.
Old Nov 20, 2004 | 01:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type SH &raquo;</TD></TR><TR><TD CLASS="quote">
A front strut bar isn't going to get you any traction. and I think you mean Rotas not rodas. What RPMs are you lanching it at?</TD></TR></TABLE>
I usually launch at around 4k!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Traction bars (when they finally come out), and motor mount inserts.</TD></TR></TABLE>
Any recomendations for inserts? (brand or manufacturer)
LCON or Anthony
Who are they? Anyone have contact info?
Thanks alot everyone for your help.
Old Nov 20, 2004 | 01:59 PM
Hawkze_2.3's Avatar
Energy Suspension has good inserts--https://honda-tech.com/zerothread?id=713941
Anthony is a member on this board (PrecisionH23a)--https://honda-tech.com/zerothread?id=902329
LCON is another company that just recently asked who would be interested.
Old Nov 20, 2004 | 02:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Energy Suspension has good inserts--https://honda-tech.com/zerothread?id=713941
LCON is another company that just recently asked who would be interested.</TD></TR></TABLE>
Thanks for the help, anyone have contact info on LCON?
Old Nov 20, 2004 | 05:03 PM
SuperSlow's Avatar
LCON will start making them for our car if there is enough interest. He quoted me $450 for them. Replaces front crossmember, and includes front motor mount. Their products for DA and EP look great. Check out the sponsor suspension forum.
Old Nov 20, 2004 | 05:09 PM
ek9hatch0WN3R's Avatar
yeap, poly inserts will help a little, but you may just be launching at too high of an RPM too. 4k sounds okay though, which is weird that youd get bad wheel hop.
i agree that traction bars would be a pain too, someone's gotta have a better idea to fix this problem. im kinda curious now too
Old Nov 20, 2004 | 10:11 PM
Default Re: Traction problem (ek9hatch0WN3R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9hatch0WN3R &raquo;</TD></TR><TR><TD CLASS="quote">yeap, poly inserts will help a little, but you may just be launching at too high of an RPM too. 4k sounds okay though, which is weird that youd get bad wheel hop.
i agree that traction bars would be a pain too, someone's gotta have a better idea to fix this problem. im kinda curious now too</TD></TR></TABLE>
do you have the same problem? have you done all the suggested fixes?
Also if anyone has had this problem and has any other suggestions for a cure I am still open too other options.
Thanks
P.S. - I should also state that I am using a tein ss full coilover system. Do adjustments I make with the dampening have an effect on wheel hop? I haven't noticed a difference, but have been focusing more on ride handeling and comfort then traction with those adjustments.
Old Nov 20, 2004 | 10:53 PM
john d
Guest
Posts: n/a
cant wait for the traction bars
Old Nov 21, 2004 | 07:55 AM
kb58's Avatar
Banned
Default Re: Traction problem (john d)
How come no one mentioned shocks? Seems like they'd be a huge part of the equation.
Old Nov 21, 2004 | 08:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john d &raquo;</TD></TR><TR><TD CLASS="quote">
cant wait for the traction bars </TD></TR></TABLE>
Whos making them for 5th gens?
Old Nov 21, 2004 | 08:35 AM
hOndafienD 04's Avatar
no1 makes any traction bars for any prelude....yet...any1 wanna make some custom ones out of home depot ****?
Old Nov 21, 2004 | 09:37 AM
PrettyLude's Avatar
they make them just for the 4th gens nothing yet for the fifth gens, i've even ask l-con and full race, they said if they get enough interest in it, they will start making it
Old Nov 21, 2004 | 10:35 AM
street_ruler's Avatar
actually i found somthing out...im a 3rd genner though, but we all have a similar suspensionn deisgn...
and this is the really short version
the traction bars that civics have are designed to put more preassure on certian parts of the suspension to "load" them before launching the car...teh war our cars are designed, if you replace the bushings in tehre with poly bushings, or just get teh old worn out ones out of there, it will do teh same as what a traction bar will do for a civic...so try that first if you cna, go get some new bushings, poly is best but rubber is better than 10yr old bushings...
good luck
Old Nov 21, 2004 | 02:49 PM
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">they make them just for the 4th gens nothing yet for the fifth gens, i've even ask l-con and full race, they said if they get enough interest in it, they will start making it</TD></TR></TABLE>
who makes them for the fourth gen?
Old Nov 21, 2004 | 05:15 PM
PrettyLude's Avatar
L-con
Old Nov 21, 2004 | 05:16 PM
they got a website or something?
Old Nov 21, 2004 | 07:00 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">L-con</TD></TR></TABLE>
Have they actually made any yet? I went through the thread in the classifieds and he said he was waiting for more demand before he would make them...
hOndafienD 04, I don't think they have a website, but Camp1320 sells them.
