injectors
Old Nov 21, 2004 | 04:43 PM
Boost3d22's Avatar
Default injectors
Hey guys i was on ebay browsing like always and found an auction for 850cc injectors off of a WRX, the seller is advertising that they are compatable with hondas... would they work on my 5th gen
Old Nov 21, 2004 | 04:44 PM
Boost3d22's Avatar
Default Re: injectors (Boost3d22)
ALso another thing... would 450cc be good to run say 12 psi with ? or evern 10 daily with a afcII at (60psi fuel pressure or with a Vortec 12:1 Fmu?)
Old Nov 21, 2004 | 04:54 PM
john d
Guest
Posts: n/a
Default Re: injectors (john d)
hmm it might help if you would list your set up/what kind of injectors they are...ect..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost3d22 &raquo;</TD></TR><TR><TD CLASS="quote">ALso another thing... would 450cc be good to run say 12 psi with ? or evern 10 daily with a afcII at (60psi fuel pressure or with a Vortec 12:1 Fmu?) </TD></TR></TABLE>
you can run 12psi off of 450cc but it depends on what turbo you are running and how much power its making. and yeah go ahead and run an afc and fmu
Old Nov 21, 2004 | 05:26 PM
2lude4u's Avatar
Usually injectors over 400cc or so are peak and hold, while your 5th gen is saturated. Find out if the WRX injectors are peak and hold (which they more than likely are), if so you'll want to pick up a resistor box from a 4th gen lude, or other mid/lower nineties hondas.
IDriveHonda
Sep 23, 2004 09:50 PM
jonnybravo
Jun 21, 2004 09:52 PM
SpdFrk
Aug 8, 2003 07:16 PM
GOLDBERG
Apr 13, 2003 05:16 PM
bottlefedb18c1
Jul 1, 2002 11:50 PM
