Lowering Spring Installation
Old Nov 20, 2004 | 04:16 AM
ralpheezy's Avatar
Default Lowering Spring Installation
I just bought some Eibach Sportline Lowering Springs for my 95 Prelude Si.
I took it to a GoodYear shop and they want to charge me $1,112.43.
That's just a ******* rip-off right there.
What is a good price shops should charge to install lowering springs?
And also if I can't find a good one I'll just do it myself.
Does anyone have a write-up on how to install the lowering springs or can anyone just post up the steps?
Thanks.
Old Nov 20, 2004 | 04:22 AM
stefan_s66's Avatar
Default Re: Lowering Spring Installation (ralpheyizzle)
Ya, that sounds pretty expensive. Ask around. You might be able to find intstructions on how to install em.
Old Nov 20, 2004 | 07:11 AM
ralpheezy's Avatar
Default Re: (Chase)
I just laughed in their face and left.
I searched and I didn't get anything about the install.
Only on little specific things like if someone needs to changed the ball joints or something.
Old Nov 20, 2004 | 07:21 AM
homesauce's Avatar
Default Re: (ralpheyizzle)
http://www.ntpog.org/mods/fift...shtml
Came out of reading some archived threads through the search btw.
Old Nov 20, 2004 | 07:22 AM
ralpheezy's Avatar
Default Re: (homesauce)
This is for the 5th gen though.
Will it work for a 4th gen?
*edit* I'm reading it now. I didn't see this. I searched "spring installation" and "lowering spring installation" when I searched. What did you use?
Old Nov 20, 2004 | 07:35 AM
homesauce's Avatar
It should be very similar if not the same for 4th gens, and at the very least should give you a good idea of what is involved with lowering springs.
I used for search "spring install"
Old Nov 20, 2004 | 09:05 AM
LudeyKrus's Avatar
The 4th gen's and 5th gen's suspension are about the exact same. Prices should be the same.
I charge ~$150 for a spring install on a Prelude locally. Most speed shops will prob. charge about $300 or so.
Old Nov 30, 2004 | 04:08 PM
tdo's Avatar
tdo
do it yourself !! takes couple hours thats it ... really easy
Old Nov 30, 2004 | 06:56 PM
prylwd's Avatar
OMG they wanted over a grand! Hahahahahaha. What a rip off. Do it yourself or ask another shop. It shouldn't take more than a couple hours, and shop rate is around 60-100 bucks, so they were way off.
Old Dec 1, 2004 | 02:25 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: (prylwd)
holy mother of rip offs, that's ******* ridiculous.
i paid around $120 to install springs on my 5th back then.
Old Dec 1, 2004 | 12:57 PM
ralpheezy's Avatar
Default Re: (STicky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STicky Tires &raquo;</TD></TR><TR><TD CLASS="quote">holy mother of rip offs, that's ******* ridiculous.
i paid around $120 to install springs on my 5th back then. </TD></TR></TABLE>
yeah, i found a better shop. they only charged me $125. i only took it since i didnt have the correct tools and that spring compressor thing. i'll post some piks up on here if anybody wants to see how it looks now.
Old Dec 1, 2004 | 12:59 PM
ralpheezy's Avatar
i need a camber kit now. my wheels tilt in really far.
whats the best company to get a camber kit from?
i was thinking of getting eibach for that too but they sell one kit per wheel so i decided to shop around first.
Old Dec 1, 2004 | 07:22 PM
Prolink's Avatar
Get an alignment done first.
Old Dec 2, 2004 | 01:33 PM
ralpheezy's Avatar
Default Re: (Prolink)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prolink &raquo;</TD></TR><TR><TD CLASS="quote">Get an alignment done first.</TD></TR></TABLE>
isn't that what a camber kit does?
sorry if that was a dumb question.
Old Dec 2, 2004 | 03:07 PM
jc836's Avatar
You CANNOT just buy any Camber kit-get the alignment printout snd that will tell you how far away from spec you are. Could be that you might not need kits on all 4 corners. We use SPC balljoints for the front and Ingalls adjustable anchor bolts in the rear of our 5th gen. SPC has them for the rear too. You can buy the Eibach kits-but they are made by someone for them-why not use SPC or Ingalls. We ordered from Ultra Performance in Tucson and the deal was very reasonable. Your biggest expense will be the install and final alignment.
Old Dec 2, 2004 | 03:26 PM
ralpheezy's Avatar
Default Re: Lowering Spring Installation (jc836)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jc836 &raquo;</TD></TR><TR><TD CLASS="quote">You CANNOT just buy any Camber kit-get the alignment printout snd that will tell you how far away from spec you are. Could be that you might not need kits on all 4 corners. We use SPC balljoints for the front and Ingalls adjustable anchor bolts in the rear of our 5th gen. SPC has them for the rear too. You can buy the Eibach kits-but they are made by someone for them-why not use SPC or Ingalls. We ordered from Ultra Performance in Tucson and the deal was very reasonable. Your biggest expense will be the install and final alignment.</TD></TR></TABLE>
how much should an alignment normally cost?
when you said alignment do you mean they do an alignment or do they just do an alignment check?
thanks for the help and info man.
Old Dec 2, 2004 | 03:57 PM
R.a.w.'s Avatar
wow i paid 80 bux installation.
Old Dec 2, 2004 | 07:01 PM
spnbb2
Guest
Posts: n/a
get a set of spring compressors from sears and follow the instructions on the ntpog.org stie
it should take you about 2 hours and only cost you $20 for the spring compressors
Old Dec 3, 2004 | 07:03 PM
ralpheezy's Avatar
Default Re: (spnbb2)
i'll do that when my brother gets his car. by that time i'll have more experience and most likely have learned more by then.
how much should an alignment check cost?
Old Dec 4, 2004 | 01:06 AM
bad-monkey's Avatar
i paid 149.99 for lifetime alignment from firestone. it's great, esp when you're changing ride ht. constantly like i am, or hitting random objects on the street because life hates you, like i hit stuff.
Old Dec 4, 2004 | 08:15 AM
LudeyKrus's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">i paid 149.99 for lifetime alignment from firestone. it's great, esp when you're changing ride ht. constantly like i am, or hitting random objects on the street because life hates you, like i hit stuff.
Really?!
I may have to see if i have a firestone in my area!
Old Dec 4, 2004 | 08:26 AM
lakerschamp2000's Avatar
Default Re: (LudeyKrus)
shops where i live charge only 60 bucks to install. Reason why they charge so cheap because most of us here install by ourselves.
Old Dec 4, 2004 | 10:20 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">Really?!
I may have to see if i have a firestone in my area!</TD></TR></TABLE>
i think goodyear and other national chains may have a similar deal.
it's really a sweet deal.
Honder07si
Honda Civic (2006 - 2015)
Jul 30, 2008 02:13 PM
chris215chris
Mar 19, 2003 04:35 PM
NONKonformyst
Mar 29, 2002 05:18 PM
redteg1
Jul 31, 2001 12:46 PM
