NEED HELP REALLY QUICK!
Old Dec 19, 2004 | 07:18 PM
95greenlude's Avatar
Default NEED HELP REALLY QUICK!
i have no clue what is wrong.....
i go out to bleed my slave cylinder, and unscrew the bleeder. the clutch looses pressure and wont come back up....it'll just slam to the floor. i found out i bled the cylinder wrong, i just opened the slave cylinder and pumped the clutch, that wasnt right. so i'm sitting here stranded at my moms house with no car and i dont know what to do.
help is greatly appreciated, jared
Modified by 95greenlude at 10:18 AM 12/20/2004
Old Dec 19, 2004 | 07:33 PM
BrokeLude's Avatar
Default Re: NEED HELP REALLY QUICK! (95greenlude)
What exactly did you do to try and bleed it?
You need to make sure the reservoir stays full, and you have somebody depress the clutch, open valve, close valve, release clutch. Repeat until all the air is out. If the pedal doesn't return to the top at first, they will have to grab it and pull it up. Basically, the order is very important, and if you don't follow it exactly, it will never work.
Old Dec 19, 2004 | 07:36 PM
Default Re: NEED HELP REALLY QUICK! (BrokeLude)
so i did it wrong.....i just opened the slave cylinder, and started to pump the clutch....i need a new slave cylinder now?
Old Dec 19, 2004 | 08:00 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">i need a new slave cylinder now? </TD></TR></TABLE>
why would you need a new slave clyinder?
Old Dec 19, 2004 | 08:19 PM
Default Re: NEED HELP REALLY QUICK! (SKDRCR)
so i just go and bleed it and it should work???
Old Dec 20, 2004 | 09:18 AM
morning, edit, bump
Old Dec 20, 2004 | 09:24 AM
BrokeLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95greenlude &raquo;</TD></TR><TR><TD CLASS="quote">so i just go and bleed it and it should work???</TD></TR></TABLE>
yes
jtran21
Honda Civic (2001 - 2005)
Mar 11, 2013 08:32 PM
r1de4life
11
Jun 11, 2006 07:17 PM
dnt94civic
Feb 28, 2003 03:28 AM
Lei Siew Long
Oct 22, 2002 10:43 AM
LOKTiN
Mar 22, 2002 08:15 PM
