s200
Old Dec 18, 2004 | 06:48 PM
92hondalude's Avatar
Default s200
if i buy the base modle for the hondata s200 could i upgrade later to get like the full troutle shift and launch or do i have to by everything at once?
Old Dec 18, 2004 | 10:23 PM
Keith's Avatar
Default Re: s200 (92hondalude)
It's just a code you have to unlock. To get the code, you have to buy it from Hondata (or a dealer).
keith
Old Dec 19, 2004 | 06:16 AM
Default Re: s200 (Keith)
so theres no aditional hardware when you buy the upgrades
Old Dec 19, 2004 | 07:05 AM
mgags7's Avatar
no there is a clutch switch for hardware with the full throttle shift kit
Old Dec 19, 2004 | 07:25 AM
Keith's Avatar
Default Re: (mgags7)
I believe it uses the stock clutch switch, no?
BTW, you do need additional hardware for the g-sensor unit.
Keith
Old Dec 19, 2004 | 07:43 AM
mgags7's Avatar
i believe for the g-sensor there is the acutal sensor as the only hardware......
i know the clutch switch deal.....
the stock cruise switch is opposite of the hondata switch though.....the stock switch opens the circuit when you put the pedal down, the hondata closes the circuit when you put the pedal down.....
Old Dec 19, 2004 | 07:47 AM
dost the s200 take the place of a stock vtec ECU
Old Dec 19, 2004 | 07:55 AM
mgags7's Avatar
no, it plugs into almost any OTHER honda ecu, your p13/14 will not work. you should get a p28 and get it socketed.....this all is of course covered on hondata's website, easily located at hondata.com
crx1856
Oct 25, 2003 04:56 PM
MEANB18
Oct 14, 2003 06:03 PM
KoRE
Sep 15, 2003 07:28 PM
MindEracer
Jun 19, 2003 07:48 AM
