BAD idle!!
Old Dec 19, 2004 | 10:31 AM
Krayzielix's Avatar
Default BAD idle!!
my car idles real bad..it jumps up and down..and last nite while im braking or at a redlight..it surges all the way up to 5-6k btw its a 93
Old Dec 19, 2004 | 10:59 AM
redlude04's Avatar
Default Re: BAD idle!! (k12ayz1e)
Mine is doing that too it hasnt jumped to 5 or 6 yet, But still when i am in idle it usually goes from 1 to 2 grand. i thought it might be doing that to warm itself up but still does it when it has been running for hours.I dont know whats wrong i thought it might b the ecu, I dont know any help would be appreciated.
Old Dec 19, 2004 | 01:02 PM
prylwd's Avatar
Does it idle bad when its cold, warm, or both? Check for vacum leaks, check the tps, map, and iacv with a multimeter.
Old Dec 19, 2004 | 01:12 PM
redlude04's Avatar
Default Re: (prylwd)
It does it both for me i just recently noticed it during winter, But if the question was does it do it when the car is warm then yes it still does it warm.
Old Dec 19, 2004 | 01:24 PM
vtec_crazy's Avatar
Default Re: (redlude04)
mate its got to do with you vacume and your hoses or your injection is dirty.
i had that nad i too k it to honda nad they cleaned out my injection adn found a air hose unplugged.
somthibng simple.
get carbon cleanerand sprey it in the injector and c for any loose air hoses to the injection
Old Dec 19, 2004 | 01:26 PM
Lude-acris's Avatar
mine did the exact same thing, i tweaked with my cold start valve and it went away, try that out.
Old Dec 19, 2004 | 02:13 PM
Krayzielix's Avatar
Default Re: BAD idle!! (Lude-acris)
thanks for the replies...i havent had a chance to go look at it yet...im thinkin its tha map or vaccum leak..any more info would be good..
Old Dec 19, 2004 | 03:31 PM
britishlude's Avatar
I dug up this thread for you it turned out to be the fast idle valve circled in the pic, and it needed the plastic slider screwing down.
http://www.preludepower.com/ph...+idle
Old Dec 19, 2004 | 04:25 PM
92hondalude's Avatar
Default Re: (mzoghbi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mzoghbi &raquo;</TD></TR><TR><TD CLASS="quote">mate its got to do with you vacume and your hoses or your injection is dirty.
somthibng simple.
Old Dec 19, 2004 | 07:46 PM
Sc00teR_92h23's Avatar
Default Re: (92hondalude)
im having the same problem i got a 93 lude tho..
all the things excluding the clogged injectors is wrong but wont hurt to get them done lol
it can also be caused by low coolant and or air in the system..
id check your coolant level soon lol
but thats only for slight surges.. 1-2 grand
not the 1-5 grand like the other guy lol thats probably your floor mat getting caught lol.. seeen it happen.. car revs its *** off at like 5gs lol
kinda funny (till you smack something)
Old Dec 19, 2004 | 08:06 PM
spoolude's Avatar
Default Re: (Sc00teR_92h23)
cant belive no body said spark plugs.. theres a good chance that if u chang ur spark plugs and or spark plug wires it should smooth things out..
Old Dec 19, 2004 | 09:10 PM
Krayzielix's Avatar
Default Re: (spoolude)
aite koo..ill take a look at all those things tomorrow
Old Dec 19, 2004 | 09:30 PM
PrettyLude's Avatar
check the idle air control valve also
Old Dec 20, 2004 | 02:19 PM
Default Re: (PrettyLude)
yeah these ar eall probable causes.. theres like 400 things you can check but this guys having this problem all of a sudden cuz its cold..
can rule out alot of things... u can add fuel filter and filter sock if you really want to be hard core.. but usually something like that will give you this problem constantly.. this is happening only when cold....
Old Dec 20, 2004 | 05:20 PM
Cloud_Kicker's Avatar
hey whats man...
My prelude would idle real bad and even jump on the RPM scale while I was driving. The problem was a loose wire in the distributor cap, the wiring harness. I had to replace the ignition control module and then made sure that the insulator caps that are covering the wires in the distributor cap, had not been burned or exposing any of the wire connectors. After that, my prelude was working in top notch condition. I too, have a 93 prelude. mine is a SI. THis shoul dtake care of the problem. I had been trying to solve it for several months. And finally found the problem. Give it a try, It should be your solution.
Old Dec 20, 2004 | 05:21 PM
Default Re: BAD idle!! (redlude04)
Old Dec 20, 2004 | 05:22 PM
Old Dec 20, 2004 | 05:23 PM
Old Dec 20, 2004 | 05:29 PM
Hawkze_2.3's Avatar
Default Re: (Cloud_Kicker)
Brilliant new post-***** tactic! Post everything 5 times
Old Dec 31, 2004 | 05:46 PM
redlude04's Avatar
Default Re: (Hawkze_2.3)
I fixed mine today i thought it was the fast idle valve,I couldnt place it though so i took it to honda they said 270 dollars to replace it.I was like no and took it home unscrewed it and the screw practically fell in my hand so i tightned it put a new gasket on,put it all back on and so far its running real smooth.Saved myself 270 dollars .
Old Dec 31, 2004 | 05:53 PM
redlude04's Avatar
Oh and forgot to say thanks for all your suggestions about what it could be couldnt have done it without you guys.
omar pelayo
Dec 3, 2018 10:50 PM
KidDxbOrI
Jan 14, 2014 04:29 PM
UNKNOWN_MEMBER
Aug 11, 2005 08:56 PM
ITSTOCK
Oct 28, 2004 12:03 PM
E-spec Tuner
May 29, 2004 10:30 AM
