headlight problem
Old Mar 7, 2005 | 08:06 PM
AznBlueBoy's Avatar
Default headlight problem
my headlights will turn on but after awhile it will just turn off but the gauges inside and everything is still on. also the rear lights from having the headlights are still on also but the headlights are flickering on and off randomly....
anybody know whats wrong? and how i can fix this?
Old Mar 7, 2005 | 08:13 PM
The Phil's Avatar
Default Re: headlight problem (AznBlueBoy)
Did you do the USDM>JDM headlight swap (in the case of a 4th gen) or any kind of work on the wiring of the headlights? (any gen...obviously)
What year is your car anyway?
Old Mar 7, 2005 | 10:17 PM
Shakes's Avatar
space cadet
Default Re: headlight problem (xthephilx)
same **** happened to me. pull the plugs off of the bulbs and wipe all of the grease and such off of them. both on the bulb plugs and in the rubber plug itself. i have had no problems since i did that.
Old Mar 7, 2005 | 11:12 PM
chihuahuamanx's Avatar
Default Re: headlight problem (Shakes)
yea clean the **** off, and get new electrical goo. i did the same 100% since.
Old Mar 8, 2005 | 05:53 AM
britishlude's Avatar
Check all your ground connections also, and make sure they have good clean and firm contacts.
Old Mar 8, 2005 | 09:35 AM
vtecludeh22's Avatar
Default Re: headlight problem (britishlude)
clean and check the connections to make sure they arn't loose.
Old Mar 8, 2005 | 08:27 PM
AznBlueBoy's Avatar
Default Re: headlight problem (vtecludeh22)
these are usdm headlights
i will try and clean them but what do i clean them with?
Old Mar 8, 2005 | 10:02 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">same **** happened to me. pull the plugs off of the bulbs and wipe all of the grease and such off of them. both on the bulb plugs and in the rubber plug itself. i have had no problems since i did that.</TD></TR></TABLE>
Old Mar 8, 2005 | 11:23 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy &raquo;</TD></TR><TR><TD CLASS="quote">these are usdm headlights
i will try and clean them but what do i clean them with?</TD></TR></TABLE>
i used a napkin. anything will work, all you are doing is wiping the gunk and greese off. i wouldnt use a solvent of any kind, just a dry towel of some sort.
Old Mar 9, 2005 | 06:29 AM
4.6LJeepXJ's Avatar
And dont touch the bulbs with your hands when your done..the grease from your fingers gets so hot on them it can cause them to burst.
Old Mar 9, 2005 | 06:31 AM
Shakes's Avatar
space cadet
Default Re: headlight problem (4.6LJeepXJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4.6LJeepXJ &raquo;</TD></TR><TR><TD CLASS="quote">And dont touch the bulbs with your hands when your done..the grease from your fingers gets so hot on them it can cause them to burst.</TD></TR></TABLE>
you dont need to take the bulb out so there is no worry of that. the prongs are in finger reach.
Old Mar 9, 2005 | 07:23 AM
ViZ's Avatar
ViZ
go buy some contact cleaner and spray them
Old Mar 13, 2005 | 12:34 AM
AznBlueBoy's Avatar
Default Re: headlight problem (ViZ)
ok well i wiped them off and im still having the same problem. also when i took unplugged the bulbs, there wasn't much gunk or anything stuck in there? it looked pretty clean already but with some dust...thats about it..
where could i check the ground wires?
Old Mar 14, 2005 | 01:33 AM
AznBlueBoy's Avatar
anybody?
Roybal 3
Aug 18, 2008 12:37 PM
EK SQUAD 425
Jul 29, 2007 12:24 PM
SIKCAR
Honda S2000
Nov 21, 2005 04:20 AM
thomst4R
Jul 24, 2005 04:58 AM
BlendedEJ8
Feb 8, 2003 09:11 AM
