Got a code 4 chk engine light now WTF
Old Mar 3, 2005 | 05:33 PM
PreludeSiTdriver's Avatar
Default Got a code 4 chk engine light now WTF
I am so fking fustrated with my car its pissing me off to the point where i wish i never done anything to it. First no power after a brand new motor was droped in. Now my computer is throwing the 4 code which states my crank pos censor, something is dicked up with it. Well, I go get another distributor and the **** still gives me the code. Checked all wires and all have resistance and the continuity goes all the way to the conector that goes into the ecu. What can this **** be? It happened after I did a compression test on my motor. I am getting really agravated with this project.
Old Mar 3, 2005 | 09:35 PM
eK9aT10pSi's Avatar
Default Re: Got a code 4 chk engine light now WTF (PreludeSiTdriver)
did the sensor come loose ? its right under the IM on the driver side i believe
Old Mar 4, 2005 | 03:37 PM
i am gonna disconect ever conector visible and then plug them all back with the battery off and see what i get from that.
Old Mar 4, 2005 | 03:58 PM
britishlude's Avatar
Default Re: (PreludeSiTdriver)
Did you reset the ECU after you fitted the new distributor, to remove the code ?
Old Mar 4, 2005 | 07:29 PM
Default Re: (britishlude)
it is my ecu. i checked it with my friends ecu and it didnt give a code
Old Mar 5, 2005 | 05:21 AM
jc836's Avatar
Wiring error. Get the Helm and trace it out. Or as you have tested-the ECU was trashed.
superslowcrx91
Sep 30, 2013 12:54 PM
ilikejesus
Jul 2, 2007 06:10 PM
ineedmoney
Sep 18, 2004 08:53 AM
