i need helpppp
Old Mar 1, 2005 | 03:45 PM
93sleeper's Avatar
Default i need helpppp
ok i got to type this fast so no triping on my grammer. i have a oil leak and alot more oil leaks, i go through about a half quart every two weeks but i got 800 dollers now from taxes so should i save and buy a new engine or get all seals replaced my engine has 129,000 miles let me know any help would be good.
Old Mar 1, 2005 | 03:57 PM
The Phil's Avatar
Default Re: i need helpppp (93sleeper)
ok i got to type this fast too do you have vtech in your car mang!??
Um...yeah. If you hit vtec you burn oil. Fact of life. Although that does seem a bit too much... $800 is more than enough to get somebody to take a look at it to look for oil leaks.
Definately don't buy a new engine, that would just be a waste of money.
Old Mar 2, 2005 | 09:59 PM
eMpAtHy's Avatar
hrmm, maybe oil is leaking into the pistons and is just burning off...or do you see it leaking on the floor? if its leaking on the floor, your problems arnt as big, but if its burning, you might have ibgger problems.
Old Mar 3, 2005 | 01:23 AM
Akhany's Avatar
Default Re: i need helpppp (eMpAtHy)
Have any smoke coming out of your engine bay after you stop? Or while you're driving?
Old Mar 3, 2005 | 06:21 AM
RemerLex11's Avatar
Default Re: i need helpppp (Akhany)
if its leaking from the oil pan, you might need to replace the gasket, but before doing that get STP stop engine leak. all you do is pour it into the oil, and let it idle for like 20 min, it rejouvenates seals and gaskets.
Old Mar 3, 2005 | 07:29 AM
93sleeper's Avatar
On next week tuesday my mechanic is going to look at it and see where the oil is leaking from.i see it coming from the oil pan and the crank case and also looks like from somewhere else but anyway i replaced the oil pan gasket twice maybe im over tightening. Um no it doesnt smoke only when adding injector cleaner which is normal i think.
Old Mar 3, 2005 | 07:37 AM
diewX3's Avatar
Default Re: i need helpppp (Matt5745767)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matt5745767 &raquo;</TD></TR><TR><TD CLASS="quote">if its leaking from the oil pan, you might need to replace the gasket, but before doing that get STP stop engine leak. all you do is pour it into the oil, and let it idle for like 20 min, it rejouvenates seals and gaskets.</TD></TR></TABLE>Interesting, anyone have truth to this? I have slight leak from the oil pan and too lazy to put new honda bond on it
Old Mar 3, 2005 | 09:49 AM
RemerLex11's Avatar
Default Re: i need helpppp (diewX3)
used it on my fourth gen works great never leaked any oil again and its only like 5 bucks
Looney2002
Acura TL, RL & ZDX
Mar 24, 2013 05:08 PM
diyguy13
Mar 12, 2009 05:55 AM
accordingtothis
Oct 17, 2007 07:10 PM
yuen
Nov 12, 2006 06:43 AM
toykicks
Apr 21, 2006 10:58 PM
