Timing Question!!
Old Mar 9, 2005 | 11:44 AM
jaydemlude's Avatar
Default Timing Question!!
I just finished putting on the timing belt in my prelude..and when I tried to start it it would just crank over but would not start..i would have to keep my foot on the gas just to keep it alive..so then i checked the marks on the cams notice the exhaust side of the cam gear is a little off..now my question is there any other way i can adjust the timing through the distributor or do i have have to do every thing over again?? please tell me theres something that could be done!!
Old Mar 9, 2005 | 12:14 PM
jaydemlude's Avatar
Default Re: Timing Question!! (jaydemlude)
Also on the flywheel there are lines on that you match up to the timing mark right...theres 1 line and if you turn the flywheel over theres three more lines..i think...which one do i line the mark to?
Old Mar 9, 2005 | 01:08 PM
steveobb4's Avatar
Make sure you did'nt forget a ground or any vaccum lines.
Old Mar 9, 2005 | 01:15 PM
T-King's Avatar
If your cam is off youll have to put it back to 0 because the timing mark on the flywheel is your overall timing .
_______________
92 Si 4WS JDM H22a
Old Mar 9, 2005 | 01:26 PM
Speedra500's Avatar
Default Re: Timing Question!! (HondaLude92)
ok, if you cam is not in time with respect to your crankshaft, then you cannot correct it by shifting the distributor
Old Mar 9, 2005 | 01:46 PM
jaydemlude's Avatar
Default Re: Timing Question!! (Speedra500)
So which line should I line up the flyweel mark to? Theres about four marks I think.
Old Mar 9, 2005 | 03:46 PM
SKDRCR's Avatar
Line up your cam gears to where all the marks look even with the head.
Then take a look at your flywheel.
It should be on the white horizontal mark on the flywheel
when you look through the timing hole.
Or line up the white mark and look at your cam gears to see
if they are even.
You'll have to jump the service connector and use a timing gun to see
if you can adjust it to 15% btdc.
If you can't get it to 15% btdc by adjusting the distribotor, then you'll have
to take the tb off and realign all the timing marks.
aznfreakyguy
May 31, 2012 10:36 PM
Jsarv
Engine Management and Tuning
Apr 1, 2012 01:48 PM
Mikeyjarey
Aug 14, 2009 08:57 AM
Hemi_powered
Feb 4, 2006 12:46 PM
92 in the works
Feb 23, 2004 07:30 AM
