Flexpipe Leak + Code 12
Old Mar 8, 2005 | 08:25 PM
M@'s Avatar
M@
Default Flexpipe Leak + Code 12
So these are the conditions.
Would the leak cause the lean O2(edit: actually EGR Code)? If not would a leak shorten the life span of a new O2?
I need to decide if I need to fix the leak before I fix the 02.
Thanks a million
Matt
Modified by M@ at 9:42 PM 3/9/2005
Modified by M@ at 9:43 PM 3/9/2005
Old Mar 8, 2005 | 08:31 PM
JDMF22B's Avatar
Default Re: Flexpipe Leak + Code 12 (M@)
Fix the leak, reset the ecu, see if the o2 is still being thrown *could be just temp, because the leak is causing it to work improperly*, if the o2 code is still being thrown, replace it... thats what id do anyway... if u just get a new o2 and no leak fix, ur just going to ruin that o2 as well... and besides that fact, who <u>wants</u> to run with a leak anyway =d
Old Mar 8, 2005 | 10:04 PM
M@'s Avatar
M@
Default Re: Flexpipe Leak + Code 12 (JDMF22B)
Agreed, no one wants a leak, but to get it fixed i need a new header. So U could say a poor college student wants to.
Old Mar 8, 2005 | 11:31 PM
greatbiggiants's Avatar
Code 12 is egr not o2
Old Mar 8, 2005 | 11:33 PM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote">Agreed, no one wants a leak, but to get it fixed i need a new header. So U could say a poor college student wants to.</TD></TR></TABLE>
Who told you that?
I've had my flexpipe replaced 3 times. It's a 30 part and takes 20 mintues to remove the old busted one and install the new one. Should be less than 100 parts and labor at any muffler shop.
You do NOT need to replace the header , whoever told you that is an *******.
Old Mar 9, 2005 | 06:52 AM
M@'s Avatar
M@
Default Re: Flexpipe Leak + Code 12 (bb6h22a)
Wow, thanks I mixed up my codes. And actually the Honda "Stealership" told me that it would need replaced. Thanks
Old Mar 9, 2005 | 11:14 AM
bb6h22a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ &raquo;</TD></TR><TR><TD CLASS="quote"> And actually the Honda "Stealership" told me that it would need replaced. Thanks
Well then, your stealership is just like every other stealership - a rip off.
You can clean out your ERG valve with carb cleaner man. Simple fix, it's probably just clogged.
Old Mar 9, 2005 | 08:41 PM
M@'s Avatar
M@
Ok, so I cleaned out my EGR valve and it seems to have fixed the problem.
So, if anyone has intermittent code 12's try this out. When I removed the EGR and sucked the vacume hose w/ my mouth it didn't move. This could be ok, but after I cleaned it out it opened totally.
So thanks for the heads up on the exhaust, and especially the idea on cleaning the EGR out.
schweiger
Oct 23, 2012 05:38 PM
JD95hatch
May 18, 2006 02:51 PM
00EM1Si
10
Dec 18, 2003 02:06 AM
spencedogg
12
Nov 30, 2003 11:57 AM
DSRxCandyh2bEG
May 24, 2003 08:23 PM
