weird shaking??
Old Mar 3, 2005 | 09:08 PM
mr.newbie's Avatar
Default weird shaking??
well i have a 1999 base prelude and its the automatic with power shift. What happened is that i was messing around with it and this has happen alot now, when i floor it in first and 2nd once it gets to about 6500 it feels like the engine is shaking like it redlined? but redline isn't till like 7 sumthin? so why is it doing that? does ne1 know? sorry to bother u if this is just something dumb that has nothing to do with the car, but rather me. thx for the help
Old Mar 3, 2005 | 09:33 PM
eK9aT10pSi's Avatar
Default Re: weird shaking?? (mr.newbie)
check ur axles. does it make noise when ur driving, posible wheel bearing, but doubt it at this point
Old Mar 4, 2005 | 06:42 AM
RemerLex11's Avatar
Default Re: weird shaking?? (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.newbie &raquo;</TD></TR><TR><TD CLASS="quote"> i was messing around with it </TD></TR></TABLE>
does this mean you did something stupid and accidently f*ucked something up
Old Mar 4, 2005 | 09:44 AM
mr.newbie's Avatar
no i mean i was just testing it out to see how quick it was and at 6500 rpms it kinda starts shaking like it would at redline but after i tried again it didnt do it so iono wats wrong why it does it in the first place?
Old Mar 4, 2005 | 10:33 AM
eK9aT10pSi's Avatar
Default Re: (mr.newbie)
sounds like an alignment issue
Old Mar 4, 2005 | 11:36 AM
JadedGamerX's Avatar
Default Re: (eK9aT10pSi)
Where do you live in Oak Grove, I live on the border of Oak Grove... I'm no mechanic but an in person look would help.
I work in Blaine and get off at 4:30, we should meet up at the Bill's Gas Station off 22 and round lake.
Old Mar 4, 2005 | 11:42 AM
SKDRCR's Avatar
Default Re: (JadedGamerX)
Any cel codes?
Old Mar 4, 2005 | 04:32 PM
JDM-BB6's Avatar
Could be the tranny is starting to fall apart like the rest of them.I had a problem like that,the torque converter started to come loose due to the components inside falling apart. But before u get to that check the obvious,tires could be out of balance,bad axle.If they check out then look at the trans..
Old Mar 5, 2005 | 04:31 PM
mr.newbie's Avatar
yeah ill check but i'm pretty sure it's not the axle's the shaking i'm talkin about isn't the car shaking its just the engine like once u redline ur engine shakes? unless im a retard? =\ yeah thanks for the help though ill check it all out
Old Mar 5, 2005 | 05:25 PM
britishlude's Avatar
Are you sure it's not the rev limiter cutting in ? because the tach can be quite a bit off. Also have a real good inspection of all your engine mounts particularly the back one.
leoaa777
Jan 5, 2008 06:49 PM
whp
Feb 3, 2007 08:13 AM
pr0phet
Nov 3, 2005 12:32 PM
simplegreenmachine
Oct 6, 2003 06:33 PM
GreenMachineRex
Apr 16, 2003 04:11 PM
