97 lude immobilizer
1 Post
there is, but you'll have to pay someone to do it.
when you disable it it triggers a CEL, so unless you don't mind that ugly yellow light, you're kind of out of luck.
you can have it reprogrammed to fit any master key though, done at the dealer for around 70 bucks.
Re: 97 lude immobilizer (MeUglyDuckie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeUglyDuckie »</TD></TR><TR><TD CLASS="quote">why would you want it removed in the first place?</TD></TR></TABLE>
sounds fishy.
sounds fishy.
Re: 97 lude immobilizer (deca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deca »</TD></TR><TR><TD CLASS="quote">i need to remove it from my lude can anyone explain to me on how to do so</TD></TR></TABLE>
No.
No.
you can permanently override it with a spare key if you really want to. I work in these electronics daily and will tell you that I would not recommend going to the trouble unless you have a really important reason for doing so. Plus, its a good security feature anyways.
steal the car or something?
Re: (aneurysm)
not for stealing or whatsoever, i bought a wreck lude from a bodyshop and was told that it had no key, so went to dealer to buy a key and was told the only way they can program the key is to bring the car down.......
Re: (deca)
If you don't have the red key you can't make another. The only way you can make another key if you buy a whole new system...I know Because I lost my red key....But thanks to honda care warrenty I Got it replace for free....
Re: (edulerp97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 »</TD></TR><TR><TD CLASS="quote">If you don't have the red key you can't make another. The only way you can make another key if you buy a whole new system...I know Because I lost my red key....But thanks to honda care warrenty I Got it replace for free....</TD></TR></TABLE>
i didn't have the red key when i made my copy.... i just brought them my regular key and gave them my vin# and they just made me one
Re: 97 lude immobilizer (lude_roller)
in lemans terms, the red key is used to reprogram the ECU if it ever needed to be replaced
the reason honda doesn't need it to make a new key is because they reprogram the immoblizer unit to work with another code, there actually is no easy way to find out what code a particular car has without having an origanal key
the key "cut" or "Design" however, can be found by VIN number, and it will open the doors, turn on the acc. and ing, and it will even crank the car but it will not start the car
now to start a big argument there is a proceedure that can be done, to tigger a bypass
the process envolves taping the brakes, and turning on/off the ing, to a certain code,which can be provided by a honda dealer, and looking up the procedure, i found it on here about a year ago in the archives and the car will start like this upto 10 times i believe.. without a programed key, I tryed this however and it did not work but other people have had luck
Modified by JonGP4 at 3:29 PM 3/10/2005
Re: 97 lude immobilizer (JonGP4)
Then **** I wish I had this account then, but then again it's not like they made money off of me anyways...Thanks for the info....Now I know...
People should stop asking this question. It encourages other to go and 'steal' preludes. There is a way to remove it(disable), but no one other than Honda and Honda dealerships need to have that information.
RACEPAK
11
03-23-2007 01:50 PM
