Which pulley is this?
Old Mar 19, 2005 | 12:35 PM
NeriVTEC's Avatar
Default Which pulley is this?
VTEC lower, most inner crankshaft pulley??? is it the one that's after the damper? or if not which one is it?
Old Mar 19, 2005 | 12:55 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: Which pulley is this? (NeriVTEC)
the crank pullie is the one at the bottom it holds both belts
Old Mar 19, 2005 | 12:58 PM
NeriVTEC's Avatar
Default Re: Which pulley is this? (raylude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude &raquo;</TD></TR><TR><TD CLASS="quote">the crank pullie is the one at the bottom it holds both belts</TD></TR></TABLE>
Which two belts? because i am looking for the one that holds the timing belt.
Old Mar 19, 2005 | 01:34 PM
RHD_BB4T's Avatar
Both accessory belts that drive a/c, alt, p/s...
The gear that drives the timing belt - along with the belt itself - is located under the black plastic housing that's behind the crank pulley. The crank pulley, and other stuff, has to come off first to be able to get to the timing belt gear...
Is this what you are referring to ?
HTH
Old Mar 19, 2005 | 01:37 PM
NeriVTEC's Avatar
Default Re: Which pulley is this? (RHD_BB4T)
Is that i am looking for the one needed to change for the h23VTEC "VTEC lower, most inner crankshaft pulley"
Is that the one that you are saying that is inside the black palstic housing?
Old Mar 19, 2005 | 01:56 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeriVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Is that i am looking for the one needed to change for the h23VTEC "VTEC lower, most inner crankshaft pulley"
Is that the one that you are saying that is inside the black palstic housing?</TD></TR></TABLE>
YES
ABCVTEC
Sep 10, 2010 01:01 PM
Powered by VTEC
Jan 29, 2008 05:58 PM
dfabulous
10
Dec 9, 2007 11:00 PM
EG2Driver
Jun 15, 2006 07:24 PM
Jorsher
Oct 11, 2004 07:40 PM
