DRL and headlight question
Old Mar 23, 2005 | 04:13 PM
japmarket1's Avatar
Default DRL and headlight question
hey. need to remove the DRL on a 1993 SR lude. where is the fuse and which fuse is it? also i need to remove my factory headlights to seal a crack. how to i get the headlights out? thanks
Old Mar 23, 2005 | 10:30 PM
PrettyLude's Avatar
you will have to pull the bumper to take out teh lights, i think there is a fuse that says DRL for the lights in the fusebox inside the car
Old Mar 23, 2005 | 11:32 PM
SiRLudeVtec's Avatar
Default Re: DRL and headlight question (japmarket1)
All i know is its a pain to take the damn headlights out!!! A pain it was....
Old Mar 24, 2005 | 05:30 AM
VisPreludeVtec's Avatar
Default Re: DRL and headlight question (AJBurks)
i've swapped headlights about 4 times, gets easy after a while
Old Mar 24, 2005 | 09:13 AM
Knightmare69's Avatar
Can I have yor DRL wiring lol. I wanna add DRL's to my boys prelude, wait, is this for a 4th or 5th Gen?
Old Mar 24, 2005 | 11:16 AM
hoehouseworker's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">you will have to pull the bumper to take out teh lights, i think there is a fuse that says DRL for the lights in the fusebox inside the car</TD></TR></TABLE>
Don't forget you have to take off the heavy front bumper support also. Two bolts on each side, you will need an extension for one or two of them.
BTW: I have two OEM headlights in near perfect condition up for sale, PM for details I will let them go pretty cheap.
Old Mar 24, 2005 | 12:38 PM
japmarket1's Avatar
thanks. anyone know how to take off that front bumper. its for a 1993 lude. where do i start?
Old Mar 24, 2005 | 12:58 PM
K, so I'm gettin your DRL's for this info right? lol
Okay, you start by takin out your bumper lights, theen you go round to each fender and pulll the lining back, you should see one screw that connecting the bumper to the fender, remove that.
Then you need to get a ratchet and extension and look behind where the bumper lights that face you are, you should see 2 bolts that reside back there, remove those.
Look behind each headlight and look for a nut that sticks out that's around a pointy screw, remove that.
Then remove all the misc. plastic screws that hold the rest of the bumper on ( the ones between the center nose grills)
I'm tryin to find the DIY that had pics but not having any luck, if someone has that page booked marked then hook this kid up.
Should take you no more than 15min tops. Hit me up if you need more info.
Old Mar 24, 2005 | 01:03 PM
japmarket1's Avatar
Default Re: (Knightmare69)
eh man thnx alot i appreciate it. ya i remember seeing pics of this step by step process but i dont know were. anyways im gonna give it a shot in a few days. thanks man
97honda_accord
Mar 23, 2015 03:28 PM
HondaVerno
May 1, 2010 09:08 PM
Ciekiller
Honda Civic (2006 - 2015)
Apr 18, 2008 02:32 PM
evolvedAP1
Jul 12, 2006 11:18 AM
GettaluvR
Aug 3, 2001 05:22 PM
