starter?
Old Mar 24, 2005 | 05:53 AM
trvis's Avatar
Default starter?
so ya i hope its just something cheap and easy to fix but here the problem.
went to leave for work last night around 12am and car just clicked, thought battery might be dead so i got a jump and it still just clicks. i don't think its the alternator because someone told me today at work that my subs would cause lights to dim when they bumped and the alternator wouldnt just go out all of a sudden.
car worked great b4.
also is it worth getting the repair kit or just replacing the entire starter( im thinking its orig starter with 250k on it)
Old Mar 24, 2005 | 06:33 AM
luda94's Avatar
Default Re: starter? (trvis)
most likely your battery is not fully charged or not capable of accepting/ holding a charge. have your battery load tested and check your alternator output. starters click when they aren't getting enough voltage, not because there is something wrong with them. good luck
Old Mar 24, 2005 | 07:03 AM
rjr162's Avatar
alt's can just die (the rectifiers (diodes) can just go)... unlikely though.. and I doubt that is your issue because your car would have started with the jump and died a few moments later.
Did you let the bat charge at all off the jumping car, or did you just fire it up right away?
As for starters.. I'm wondering something myself. I checked around and Advanced had the cheapest rebuilt ones at $50. Anyone know if these things are reliable at all? My friend got 3 alt's from them for his accord before he gave up and went elsewhere to find one that worked.
Old Mar 24, 2005 | 07:19 AM
trvis's Avatar
Default Re: starter? (rjr162)
just fired it up off the jump right away. since it stopped raining im gunna go outside and take the battery and starter out then get tested. if both fine then gunna mess with belts and get the alternator off and tested.
Old Mar 24, 2005 | 09:19 AM
PrettyLude's Avatar
Default Re: starter? (luda94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luda94 &raquo;</TD></TR><TR><TD CLASS="quote">most likely your battery is not fully charged or not capable of accepting/ holding a charge. have your battery load tested and check your alternator output. starters click when they aren't getting enough voltage, not because there is something wrong with them. good luck</TD></TR></TABLE>
Old Mar 24, 2005 | 09:53 AM
trvis's Avatar
well battery and starter are fine, one guy at advanced said i needed to replace the starter because it smelled electrical, took it to another place and the guy said it wasn't the problem and he didnt smell ****.
right now im putting off taking out my alternator, just looked in the book and it looks like a bitch :/
edit: just went out and looked around at the wires(since the pwr wire to my amp coroded off the post D and noticed the ground wire to the starter is all frayed and unwrapped, connecter is also loose) gunna go put everything back in and heat shrink the frayed ground wire and see if it works b4 getting the alt.
Old Mar 24, 2005 | 10:37 AM
VisPreludeVtec's Avatar
Default Re: (trvis)
check the negative battery terminal for corrosion too because I had this problem and I had some corrosion ont he neg bat. terminal
Old Mar 24, 2005 | 01:02 PM
trvis's Avatar
was just going to put the battery back in when i noticed 2 small indentions in the battery with liquid around them.. put my thumb in it and didnt burn so im guessing its not battery acid.. dunno if this is the problem or not. when i tested it it tested fine
Old Mar 25, 2005 | 06:49 AM
trvis's Avatar
Default Re: (trvis)
new battery in and it does the same thing.
put key in ign
turn to acc everything comes on
turn to start and it just clicks once and everything dies( i can hear the starter trying to start and also a clicking on the inside sounds like its comming from the fuse box)
then its dead for about 20 seconds and everything will come back on in acc again
Modified by trvis at 8:10 AM 3/25/2005
Old Mar 25, 2005 | 08:17 AM
PrettyLude's Avatar
looked at the fuses real good? check them again, and check the relays too
Old Mar 25, 2005 | 08:23 AM
IHateJDM's Avatar
Default Re: (trvis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trvis &raquo;</TD></TR><TR><TD CLASS="quote"> put my thumb in it and didnt burn so im guessing its not battery acid.. </TD></TR></TABLE>
funny...
but anyways, how much power is your amp pulling? What guage power + ground are you running? Is it more than the alternator can charge? If you aren't sure, just look at the amp and see what fuses it has in it. I can tell you from there.
Old Mar 25, 2005 | 08:32 AM
trvis's Avatar
Default Re: (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
funny...
but anyways, how much power is your amp pulling? What guage power + ground are you running? </TD></TR></TABLE>
amp as in the one running my subs? ya.. the pwr cable connected to the battery coroded off when i was removing the terminal so system has now pwr and still same problem. gunna go check fuses and relays after i get showered and dressed
edit: really need to get this fixed so i can go out of town for easter D: my moms pissed
Old Mar 25, 2005 | 08:35 AM
IHateJDM's Avatar
Default Re: (trvis)
pour some coke on the corrosion, it'll eat it right off. other than that, fix frayed wires and check all your grounds.
Old Mar 25, 2005 | 10:17 AM
trvis's Avatar
that wad all done
got a post cleaner tool and wrapped the wires in electrical tape
still havent got outside to check fuses
Old Mar 25, 2005 | 11:18 AM
trvis's Avatar
Default Re: (trvis)
grounds wires and fuses are fine
i found this fkn little switch tho with a reset button next to it by the fuse box on the inside no ******* clue wtf it is
ok since:
You are not authorized to post more than 5 messages per 24 hour period. Please try again later.
GAY
it looks like an aftermarket alarm switch or some gay ****, im having someone contact the previous owner right now to see wtf it is.
Modified by trvis at 12:35 PM 3/25/2005
Old Mar 25, 2005 | 11:29 AM
IHateJDM's Avatar
Default Re: (trvis)
is it a button or a switch? can't check myself, i don't have a lude, just the engine.
Old Mar 25, 2005 | 03:10 PM
trvis's Avatar
its aftermarket alarm and jus tthe bottons are there nothing else
but ya i give up gunna get it to a mechanic tomorrow
Modified by trvis at 6:23 PM 3/25/2005
man this post limit is gay ****
i took the starter out and had it tested at 2 diff places, both said it was within params to start the engine, one guy said 'it smelled electrical and should be replaced.
to restate the problem:
turn the key to acc and warning lights all come on with ssr then i turn it to start and it clicks and all the lights die, it stays in acc and the lights slowly come back on and it does the same thing
Modified by trvis at 7:20 PM 3/25/2005
Old Mar 25, 2005 | 05:46 PM
SnlpeR's Avatar
grad a big hammer and whack the starter
get back inside and try cranking again
Old Mar 26, 2005 | 09:40 AM
trvis's Avatar
bump
Old Mar 26, 2005 | 10:39 AM
dmxsoulja3's Avatar
Default Re: (trvis)
my car did this, two reasons, corrosion on the negative battery terminal that lead to my alarm arming itself, which then lead to the starter disable relay not functioning and keeping the car from starting. my lights did the SAME thing, to the T. cleaned the terminal, towed the car, got a new alarm put in....working perfect, now.
Old Mar 26, 2005 | 11:02 AM
trvis's Avatar
Default Re: (dmxsoulja3)
well my neg terminal wasnt corroded at all
but the + was all coroded even coroded off my amp pwr wire
so im guessing thats it
i can just pull off the terminal and cut the wire and replace the terminal farther back if i have to correct?
pervious owner said he removed all of the alarm except the switches so i dunno what, maybe the relay went bad?
elmejor
Nov 6, 2008 07:12 AM
Integ808
Oct 16, 2008 02:57 AM
01-0720
Feb 3, 2005 04:23 PM
95greenteg
Nov 29, 2004 02:56 PM
Hung
Apr 20, 2002 02:58 PM
