switching ECUs...
Old Mar 24, 2005 | 06:50 AM
TruNinja619's Avatar
Default switching ECUs...
has anybody used the ECU off a S model on a Si???.. if so, did it work properly???
I know its kinda farfetched, but its worth a try asking..
i'm curious b/c my cel light is on (its the knock sensor) and seeing how the S model doesn't have a knock sensor.... well.. just curious if it'll work properly..
my smog date is coming up soon and the non-functioning knock sensor won't let me pass...
Old Mar 24, 2005 | 08:55 AM
prelittlelude's Avatar
Default Re: switching ECUs... (TruNinja619)
the CEL is coming on for a reason, obviously your knock sensor is gone bad.
first thing is that the f22 is a sohc and a 2.2L the h23 is a dohc 2.3L totally different engine which means the fuel and ignition maps will be off. it would probably run but how well and for how long i don't know
the other thing is that the h23 has the dual runner intake manifold which the S doesn't.
just fix your knock sensor. if this were to test if the ecu were bad, yes the car would start and idle but i wouldn't keep it that way for long
Old Mar 24, 2005 | 10:05 PM
dreams190's Avatar
does the h23 even have a knock sensor? cuz I just had my h23 swapped to an h22a and we had to wire up the knock sensor for the new motor...
Old Mar 24, 2005 | 10:06 PM
Hawkze_2.3's Avatar
Default Re: (dreams190)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreams190 &raquo;</TD></TR><TR><TD CLASS="quote">does the h23 even have a knock sensor? cuz I just had my h23 swapped to an h22a and we had to wire up the knock sensor for the new motor...</TD></TR></TABLE>
Yes it does, just replaced mine a few months ago. It's right above the oil filter...
ImprtTuner88
Sep 20, 2006 12:25 PM
LudaKris
Jun 1, 2003 01:38 AM
