How to pull codes on a 1999 prelude?
Old Mar 25, 2005 | 12:30 PM
ama0787's Avatar
Default How to pull codes on a 1999 prelude?
I am in FL and driving a girl friends car and her check engine light has came on. I would really like to check and the codes and find out what is wrong. Any help would be greatly appreciated.
TIA
Anthony
PS if interested i drive a 1994 supra turbo single turbo aem crower cams and 512 hp at 17pis on 94 octane i am usually on the supra forums and thought maybe this forum could help me with my problem
Modified by ama0787 at 2:28 PM 3/25/2005
Old Mar 25, 2005 | 12:35 PM
teg969's Avatar
Default Re: How to pull codes on a 1999 prelude? (ama0787)
to check the codes on a 5th gen lude,
take out the little carpet panel on the center consol right next to the gas pedal,
there should be a little connector there (blue i think)
just throw a paper clip in there and read the codes,
long flash = 10
short flash =1
hope this helps
Old Mar 25, 2005 | 12:37 PM
jc836's Avatar
OK A 5th gen has the connector/port is under a cover on the righthand side of the console. You will see it is covered in carpet and simply pulls off. In there are 2 connectors-one is the OBD-II connector and the other is for the jumper. That is where you need to be to pull the codes. A code scanner would be a very good thing to use. Dealers charge ~$80 for this test, btw.
Old Mar 25, 2005 | 12:49 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: How to pull codes on a 1999 prelude? (jc836)
or just go to advance auto or auto zone they will pull the code for free
Old Mar 25, 2005 | 01:36 PM
ama0787's Avatar
what console center i am assuming and by right do you mean driver or passenger side and pictures would be awesome.....I have looked all over right now passenger kick panel is off and carpet is peeled back revealing the ecu cover and more advice would eb great
Old Mar 25, 2005 | 01:57 PM
britishlude's Avatar
Default Re: (ama0787)
Hope this link helps a little : http://www.londonautoclub.org/...s.htm
Old Mar 25, 2005 | 04:46 PM
raylude's Avatar
Default Re: (britishlude)
its rite there u just pull it out and and plug the obd2 into the obd2 port
excuse the dirtyness
Old Mar 26, 2005 | 06:34 AM
lenn's Avatar
hmm... weird how nobody posted this one yet...
http://www.hondaprelude.to/art....html
but i guess the london auto club link would work as well..
Old Mar 26, 2005 | 08:22 AM
ama0787's Avatar
raylude thanks a lot that photo really helped let me know if you if i can ever help you or your friends i know just about everyway to fix a supra....ama0787 on those forums too.....thanks again
Old Mar 28, 2005 | 05:47 AM
teg969's Avatar
why the hell is mine on the driver side then :S
Old Mar 28, 2005 | 01:44 PM
raylude's Avatar
Default Re: (teg969)
wat car u got? a 5th gen?
Old Mar 28, 2005 | 02:29 PM
teg969's Avatar
Default Re: (raylude)
yes
Old Mar 28, 2005 | 06:01 PM
SoOHiGH's Avatar
ok i went to one of those links at the top and it helped but what if my CEL goes on but then when i turn my engine off then back on it goes away then a couple days later it goes on and the same thing happens. Its only goes on like 3 times a month or so.
How do I check the code if it keeps going off?
EDIT - i have a 4th gen
Old Mar 28, 2005 | 06:40 PM
SoOHiGH's Avatar
Default Re: (SoOHiGH)
nvm found it
Old Mar 28, 2005 | 07:27 PM
raylude's Avatar
teg969 i could swear that all 5th gens have it on the passengers side are you sure its a obd2 port?
Old Mar 29, 2005 | 06:29 AM
teg969's Avatar
well i sure hope so because ive been checking my codes with that, i just checked them actually last monday...maybe the wire was moved or something....
preluderemis
May 22, 2025 08:44 PM
mdjplay
Jun 10, 2004 05:54 PM
tea
Jan 14, 2004 11:12 AM
Redsim
Jun 5, 2003 04:18 PM
mdjplay
Apr 26, 2003 02:08 PM
