tech HELP
Old Mar 20, 2005 | 10:11 AM
japmarket1's Avatar
Default tech HELP
im doin fog lights on the lude. but i am planning to mount a switch somewhere along the dashboared close to the steering wheel for activation purposes. i need help on how to get the wires from under the hood to inside the car. were can i fish the wires through??? thanks
Old Mar 20, 2005 | 10:31 AM
The Phil's Avatar
Default Re: tech HELP (japmarket1)
Remove the hood fuse box. There's about a 1.5" wide hole to poke things through. I managed to get a AWG 0 wire through there fine. It just takes a bit of poking around and it'll be fine.
Old Mar 20, 2005 | 03:34 PM
japmarket1's Avatar
Default Re: tech HELP (xthephilx)
thanks. i have psi and water temp. gauges and they fished the wires through so i tried following the wires but couldnt figure out were they came from. is the hole behind the fuse box?
Old Mar 20, 2005 | 03:52 PM
The Phil's Avatar
There's a group of two nuts that are holding the fuse box to the firewall. Maybe 6" below that is the hole. It's big. You can't miss it.
tast2s
Dec 15, 2010 12:13 AM
wseg
Jan 24, 2010 10:29 PM
X-MOB03
Oct 12, 2004 11:35 AM
