gm_syncromesh
Old Apr 21, 2005 | 07:01 PM
kch22t's Avatar
Default gm_syncromesh
http://www.5speedtransmissions....html
is this the one that you guys use
Old Apr 21, 2005 | 07:02 PM
prelude1897's Avatar
Default Re: gm_syncromesh (kch22t)
Thats what I used
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kch22t &raquo;</TD></TR><TR><TD CLASS="quote">http://www.5speedtransmissions....html
is this the one that you guys use</TD></TR></TABLE>
No. We use the one that lools like a regular rectangular motor oil bottle.
Old Apr 21, 2005 | 07:04 PM
kch22t's Avatar
Default Re: gm_syncromesh (prelude1897)
thanks but does it has grade, if yes which grade did you used
does it help??
Old Apr 21, 2005 | 07:05 PM
kch22t's Avatar
Default Re: gm_syncromesh (cpforyou)
regular rectangular motor oil bottle ?? you have pic
Old Apr 21, 2005 | 07:10 PM
AndyD's Avatar
Get Pennzoil Synchromesh. It is the same thing....but MUCH cheaper. I paid $5 a quart. GM is close ot $15 if I remember correctly.
Old Apr 21, 2005 | 07:17 PM
edulerp97's Avatar
Default Re: gm_syncromesh (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Get Pennzoil Synchromesh.</TD></TR></TABLE>
Where can you get this....Local autozone...napa....CHeckers....Where?
Old Apr 21, 2005 | 07:36 PM
AndyD's Avatar
Default Re: gm_syncromesh (edulerp97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 &raquo;</TD></TR><TR><TD CLASS="quote">
Where can you get this....Local autozone...napa....CHeckers....Where?</TD></TR></TABLE>
I believe I got it from AutoZone. I know it wasn't Advanced Auto or Pepboys.
Old Apr 21, 2005 | 07:54 PM
kch22t's Avatar
is this the one
http://www.stealth316.com/2-pe...h.htm
are you sure it works as good as gm_syncromesh
Old Apr 21, 2005 | 07:57 PM
AndyD's Avatar
Yup, that's it.
Trust me, it is the same.
Old Apr 21, 2005 | 08:27 PM
gaydm.accord's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">Yup, that's it.
Trust me, it is the same.</TD></TR></TABLE>
Old Apr 21, 2005 | 10:03 PM
edulerp97's Avatar
Default Re: gm_syncromesh (gaydm.accord)
I must try it.......
Old Apr 21, 2005 | 10:35 PM
Inextricabledrvr's Avatar
how many qts are needed to fill the tranny ?
Old Apr 21, 2005 | 10:42 PM
drain and fill is about little more than 2 no more than 3
Old Apr 22, 2005 | 06:35 AM
cpforyou's Avatar
Default Re: (gaydm.accord)
There are two types, regular and friction modified. You guys are talking about te regular one.
Most people look for the friction modified one. It has friction modifiers to help synchronize things more. It helps with shifting smoother, but many speculate it'll accelerate wear on your tranny as well.
Or go to http://www.gmpartsdirect.com
Type in Part Number 12377916
Old Apr 22, 2005 | 06:56 AM
integra15's Avatar
Default Re: (cpforyou)
I've done a lot of reading on Synchromesh and here are my conclusions
For a non LSD tranny it's best to use the non friction modified type
The friction modified one can add friction to the tranny, thus supposedly "wearing it out quicker"
Modified by integra15 at 6:04 PM 4/26/2005
Old Apr 22, 2005 | 07:38 AM
92LudeSI's Avatar
I heard that you shouldnt use syncro mesh in honda trannys because it is made for GMs which have a different type of syncro stack. Thus the honda trannies will not get enough lubrication onthe bearings and such. If you think about it it sounds like it would make sense. I have been using straight syncromesh for about 2 years now and I have had no problems but I just wanted to get a few more opinions.
Old Apr 22, 2005 | 07:47 AM
gerhard's Avatar
Yep... that's exactly what I've been using.
Old Apr 22, 2005 | 09:51 AM
silver97prelude's Avatar
I used the GM in the round bottle with the blue label, It completely eliminated my 5th gear grind.
Old Apr 22, 2005 | 09:56 AM
Sabbotage's Avatar
Default Re: gm_syncromesh (silver97prelude)
yeah i always use the round bottle too. The dealer told me the square bottles are what they use in the heavy duty trucks and stuff, and they use the round bottles in cars and light trucks.
Old Apr 22, 2005 | 09:13 PM
kch22t's Avatar
Default Re: gm_syncromesh (Sabbotage)
thanks all so its the round bottle right
Old Apr 22, 2005 | 09:14 PM
kch22t's Avatar
i mean this http://www.5speedtransmissions....html
Old Apr 22, 2005 | 11:13 PM
H22Power_521's Avatar
as said above, penzoil and gm sycnromesh are the same thing. penzoil makes it for gm and gm just bottles it themselves. go to autozone and look in the heavy gear oil section. it will be within 15ft to the left or right of the motor oil. its in a tall round yellow bottle. its no more than 5 dollars a quart. and h22 transmissions take exactly 2 quarts.
Old Apr 23, 2005 | 07:44 AM
mattmw88's Avatar
Default Re: (H22Power_521)
I work at a penzoil oil change place and have bought GM syncromesh before. Straight from the 5 gallon bucket, pezoil synchromesh is a little darker than that of GM synchromesh... is there any reason for this?
Old Apr 23, 2005 | 09:45 AM
cpforyou's Avatar
Default Re: (mattmw88)
If everyone does a search....
The square bottle is Friction Modified.
GM Part Number 12377916
The round bottle from GM and the one from Penzoil is NOT Friction Modified.
Most people have better success with Frition Modified.
capcon83
Apr 24, 2017 03:55 AM
NOPIMAN
Apr 9, 2008 07:43 AM
EJtypeR
Jan 3, 2006 05:43 AM
@irborne
Welding / Fabrication
17
Nov 6, 2005 04:32 PM
mportbusta
Mar 13, 2005 11:56 PM
