h22..help
Old Apr 19, 2005 | 03:16 AM
mxer518's Avatar
Default h22..help
hey i am having some trouble with my h22..it will start and idle fine but once you tap the gas pedal it stalls out? dose anybody know why this may be?
and is it possible to run a h22 prelude on a h23 ecu...until i get my new one?
Old Apr 19, 2005 | 04:54 AM
Monkey Fing a Coconut's Avatar
Default Re: h22..help (mxer518)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mxer518 &raquo;</TD></TR><TR><TD CLASS="quote">hey i am having some trouble with my h22..it will start and idle fine but once you tap the gas pedal it stalls out? dose anybody know why this may be?
and is it possible to run a h22 prelude on a h23 ecu...until i get my new one?</TD></TR></TABLE>
its possible to run it but if u do, keep it under 3k rpm to be safe, note u will not have vtec of course
as for the stalling, so anytime u give it any gas other than just letting it sit at idle it stalls??? or if u rev it real quick when it falls back down to idle it stalls???
Old Apr 19, 2005 | 10:53 AM
mxer518's Avatar
Default Re: h22..help (twistedbydezign)
whenever it gets any gas at all.
Old Apr 19, 2005 | 11:03 AM
The Phil's Avatar
any CELs?
Old Apr 19, 2005 | 11:14 AM
mxer518's Avatar
Default Re: h22..help (xthephilx)
no...that the odd part? the car isnt throwing any cel's
Old Apr 19, 2005 | 12:07 PM
94svtec's Avatar
try checking the TPS voltage at fully closed and then at WOT. I believe it is 0.5 at closed or idle....and 4.5 volts at WOT..I had the same problem and adjusting it was what solved that problem.
Old Apr 19, 2005 | 06:40 PM
mxer518's Avatar
Default Re: h22..help (94svtec)
i am also thinking that i may have the tps and the egr plugs switched... what color wires do the tps have? and how do you adjust the tps.. i thought there was only one way to put it in....
Old Apr 19, 2005 | 06:47 PM
94svtec's Avatar
I have a JDM H22A so the TPS has screws and is not Riveted like the USDM ones.... I dont know the wire colors off hand.. do you have a helms manual??
Old Apr 19, 2005 | 07:30 PM
mxer518's Avatar
no i dont have a manual... i couldent find anyone who sold them for my car around where i live...
saikou
Dec 11, 2012 11:50 PM
dek1mfk
Nov 6, 2006 03:25 PM
777Lude
Aug 13, 2004 09:08 PM
