hondata write up needed!
Old Apr 25, 2005 | 10:56 AM
Under_Pressure's Avatar
Default hondata write up needed!
Hi I have jdm h22a ob1 prelude. My question is if I buy a s200 with boost option how do I instal it or is it just solder in the chip? I know I need to get a p28, but how would I instal it myself. I've done vafc's, alarms, car audio, nitrous so I know how to work on electronics. what need to be done. The reason iam asking is that iam going away from no2 "nos" and going turbo. I sold my nos and vafc2. Everyone says to get hondata so I going that way. Also can I use the hondata s200 With boost without my turbo for now?
Old Apr 25, 2005 | 11:16 AM
98TypeSH's Avatar
Default Re: hondata write up needed! (92h22alude)
When you buy the hondata the place u bought it from should be able to "socket" the ECU. A ZIF Socket needs to be installed and i believe a jumper has to be removed depending if its an automatic ECU or 5spd.
Also currently hondata can only be used on OBD1 P28 ECU or P72 ECU.
The P28 should work just fine and should be readily available on the FS threads.
It does require soldering/desoldering. Id let someone else do it.
Old Apr 25, 2005 | 11:32 AM
Default Re: hondata write up needed! (98TypeSH)
ok so let me get this str8, A hondata s200 is a chip? thats it "whats the blue box then?". Ill get the p28 in my aunts yunkyard easy'ly shes got like 14! after they solder the chip no wires or nuthing needs to be done? Holy **** if its like that why is it so expensive "A Chip" I know that blue box has to be like a computer.
Old Apr 25, 2005 | 12:30 PM
PrecisionH23a's Avatar
http://www.hondata.com/downloads.html has everything you need on there as far as installation and socketing.
Old Apr 25, 2005 | 01:22 PM
98TypeSH's Avatar
Default Re: hondata write up needed! (PrecisionH23a)
well does the "blue box" require any type or wiring? No, it plugs into the ECU. I was going off what you asked. I didnt know you needed me to spell it out word for word an exact retard acceptable answer. lol , good luck!
Old Apr 25, 2005 | 01:45 PM
sleeper95Lude's Avatar
Actually, if you have an H22A, you really should look for a P72. The P28 won't deal with your IAB, or with your knock sensor.
Of course, since you are going turbo, the IAB and knock are less of a concern, but it'd be nice to have until your setup is installed.
Old Apr 25, 2005 | 06:04 PM
Default Re: (sleeper95Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">well does the "blue box" require any type or wiring? No, it plugs into the ECU. I was going off what you asked. I didnt know you needed me to spell it out word for word an exact retard acceptable answer. lol , good luck!</TD></TR></TABLE>
Thats why iam asking because I dont know!
Modified by 92h22alude at 3:43 AM 4/26/2005
Rzoops
Sep 1, 2010 07:10 AM
turbodcxbro
Engine Management and Tuning
Jan 9, 2010 11:31 AM
spoonhatchblack
Dec 12, 2008 11:28 PM
inh
Apr 19, 2006 08:30 AM
StinkyTofu
Dec 29, 2002 11:51 PM
