supposedly type s head
Old Apr 21, 2005 | 06:25 AM
ebp_dc2's Avatar
Default supposedly type s head
Just put a "type S" head on my jdm h22a. How can i tell if i actually put a type s head on? it says it was made in 96 thats all i got.
Old Apr 21, 2005 | 07:19 AM
2lude4u's Avatar
Default Re: supposedly type s head (h22d dc2)
If it has P13 stamped on the head it's not a Type S. I think it should have P5P stamped on it.
Is the main difference, between a normal H22 head & a Type S, the valve/valve pocket angles?
Old Apr 21, 2005 | 11:47 AM
machine4321's Avatar
yes p5p stamp is what you want ...cams are bigger and not sure on the rest
i would like to knwo how someone got ahold of a type s head with out the botom end
Old Apr 21, 2005 | 12:06 PM
LUDEacris's Avatar
Default Re: (machine4321)
The bottom end of the H22 motors like to burn oil and depending on the setup blow. The Type-s head should also be mildly ported and polished.
Old Apr 21, 2005 | 02:56 PM
ralpheezy's Avatar
Default Re:
i'm thinking your h22 won't be a "type-s" with only the type-s head. you would need the type-s pistons too.
Old Apr 21, 2005 | 07:56 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: Re: (ralpheyizzle)
yeah the head was ment to run with typeS pistons
Old Apr 22, 2005 | 09:59 AM
ebp_dc2's Avatar
Default Re: Re: (raylude)
it doesn't have to run with that though...so look for p5p stamp on the front of the head...ill do that today...if i see p13 anywhere than its no good right?
Old Apr 24, 2005 | 05:22 PM
ebp_dc2's Avatar
Default Re: Re: (h22d dc2)
it says p13...does that mean i got ripped offf???????
Old Apr 24, 2005 | 05:44 PM
if you payed more then you should have for a p13 head ..yes
how much did you pay for it
Old Apr 25, 2005 | 06:24 AM
ebp_dc2's Avatar
not much...but that still pisses me off...he'll be hearing from me
Old Apr 25, 2005 | 07:44 AM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22d dc2 &raquo;</TD></TR><TR><TD CLASS="quote">it says p13...does that mean i got ripped offf???????</TD></TR></TABLE>
RESEARCH RESEARCH RESEARCH!
Hope you can settle it with the seller. (You didn't buy it from here, did you?)
Old Apr 25, 2005 | 09:33 AM
yea if he told you it was a type s then i would be mad however if its too go to be true it probly is ..if i got a type s head for 400 bucks i would bet it wasnt a type s head..untill i saw it
good luck
Old Apr 25, 2005 | 01:28 PM
ebp_dc2's Avatar
i actually foudn him through http://www.roclife.org which is supposed to be respectable...oh well can't win them all
T"u"Rtle
Feb 22, 2006 05:59 AM
kholmes
Apr 14, 2005 04:57 PM
VRD^don
Jan 15, 2003 09:44 AM
