Broken wheel stud
Old Apr 24, 2005 | 10:53 AM
Eucalyptus lude's Avatar
Default Broken wheel stud
While trying to remove my older lug nuts to replace em with rays ones,i snapped off one of my wheel studs on the front wheel. NOW im back to 4 lug on front right. What can i do to replace it, and is it very dificult. Thanks guys.
Old Apr 24, 2005 | 10:58 AM
The Phil's Avatar
Default Re: Broken wheel stud (Eucalyptus lude)
You can just take it out and replace it. I don't remember how to do it offhand, but you can tap them out somehow and then put a new one in.
Old Apr 24, 2005 | 11:40 AM
digitalh3lix's Avatar
u need a new wheel hub sounds like.. unless someone welds it bak.. but i dunno how long that would last.
Old Apr 24, 2005 | 11:43 AM
98vtec's Avatar
moderator emeritus
Default Re: Broken wheel stud (digitalh3lix)
you dont need a new hub, you can knock that stud out and replace it
Old Apr 24, 2005 | 11:50 AM
sexyblack93lude's Avatar
did my took about 45 minutes
preludeguy_92's Avatar
To replace the lug you have to remove the hub. Remove the rotor then use a slide hammer to take off the hub. It isnt too difficcult should only take about an hour or two.
streetracer_305
18
Jun 20, 2015 01:59 PM
Eclectia
Jun 16, 2013 11:56 AM
marvin75
Apr 24, 2011 05:48 AM
drewbie
Welding / Fabrication
Apr 21, 2006 07:28 AM
jackal
Apr 25, 2002 11:09 AM
