Starting Problem
Old Apr 20, 2005 | 12:09 PM
hondalude92si's Avatar
Default Starting Problem
Hey I'm new to this site but I have a 1992 Prelude SI and it Won't Start when it is hot out. It is cranking but it won't fire over. It is fine in the winter but as soon as the spring hits forget it. I have to wait till it cools down to start the car. Does anyone out there know why this would be happening. I would really appreciate it.
Old Apr 20, 2005 | 02:17 PM
FroOch's Avatar
Default Re: Starting Problem (hondalude92si)
Bump for this guy right here^^^
Old Apr 20, 2005 | 05:48 PM
FroOch's Avatar
Default Re: Starting Problem (FroOch)
Has noone ever experienced this before?
Old Apr 20, 2005 | 05:51 PM
high_revs's Avatar
could be a lot of stuff...when it doesnt start check for spark and fuel pressure...then we can give you a better idea...could be a lot of stuff like a fuel pump, dizzy, main relay...just need more info.
Old Apr 20, 2005 | 06:01 PM
FroOch's Avatar
Default Re: (all mOtor h23)
Yeah I've been searching and it seems this Main Relay is a real PITA and may attribute to this.
I work with the original poster and had a look at it in the parkinglot. I checked for obvious things like battery and cable connection, filter clogging and general making sure the hoses and sensors but we really didnt have any diagnosing tools handy.
I was thinking this may be a common problem among Prelude owners so I advised him to ask you guys.
We can probably pull the plugs fairly easily during lunch but are there any other little things we can try without dealing with the local Honda mechanic?
Old Apr 20, 2005 | 06:11 PM
high_revs's Avatar
yeah i named some of the things that go bad reguraly on hondas...so start by looking there...just when it doesnt start check if it has spark...if it doesnt...i would start with a new dizzy which is pretty expensive....if you do have spark and it wont start then i would move on to check fuel pressure, injector pulse etc.
Old Apr 21, 2005 | 09:59 AM
PrettyLude's Avatar
normally when its hot outside, its the main relay
Old Apr 21, 2005 | 02:06 PM
FroOch's Avatar
Default Re: (PrettyLude)
I dont know your cars too well but where can we find this thing? Is it a relay under the dash somewhere or is it something in a fuse box under the hood? Numbers, locations, colors, whatever you got. Thanks again though everyone, this is a whole lot better than one man pissin in the wind.
Old Apr 23, 2005 | 07:19 PM
PrettyLude's Avatar
its underneath the dash, on the driver side, usually they are held on by 10mm bolts
Old Apr 23, 2005 | 10:56 PM
deserthonda's Avatar
when you get the relay out ,,,take it apart. get a magnifing glass and if you look closely there is a crack on 1 or 2 of the sodering, just get a sodering gun and resoder that ( those ) cracked connections works like a charm i have done dozens of them do not buy a new relay
d_bravo06
Apr 21, 2017 06:00 AM
slvlile
Oct 5, 2010 09:58 PM
jdmjin
10
Jun 1, 2009 07:01 PM
HondaKPX
Feb 17, 2005 10:26 AM
da1foyou
Sep 11, 2003 03:00 PM
