92 si engine
Old May 18, 2005 | 05:30 PM
sohctodohc's Avatar
Default 92 si engine
what engine comes in the 92 si prelude? what are the specs on it and is it possible to swap into a 92 hatchback vx? freind found one that just needs rebuilt for a hundred dollars so we are just curious. tia
Old May 18, 2005 | 07:06 PM
Cashis Lee's Avatar
Default Re: 92 si engine (sohctodohc)
THe 92 Si comes with an H23. 160HP and I beleive 158tq. It would fit into a 92 HB, but you need to get some aftermarket mounts.
Old May 18, 2005 | 07:59 PM
sohctodohc's Avatar
Default Re: 92 si engine (Cashis Lee)
would the cv shafts mount up??? or is the mounts the only thing you would need to buy???
Old May 18, 2005 | 09:05 PM
sohctodohc's Avatar
cmon i know someone else knows bout this. plus was the h23 in the 91 si??? or was there a different one
Old May 18, 2005 | 09:18 PM
Hawkze_2.3's Avatar
The 92-96 Prelude Si had the H23. The 91 should have a B20 or B21 (I'm no expert), but no H-series until 92.
Do a little research in the Hybrid forum and you're sure to find an answer. It's the same as an H22 swap except for minor wiring and other little details...
STXLude
Apr 13, 2009 12:59 PM
circuitEG6
Sep 17, 2007 07:11 PM
stewmaster-k
Sep 3, 2005 08:43 PM
