Grounding system really work?
Old May 16, 2005 | 06:49 PM
ludewithanh22's Avatar
Default Grounding system really work?
Do you guys think a grounding system really works?? Is it worth the money.
what do you think of the ebay ones: http://cgi.ebay.com/ebaymotors...33692
Old May 16, 2005 | 06:55 PM
The Phil's Avatar
Default Re: Grounding system really work? (ludewithanh22)
Can't speak for the voltage stabilizing thing...but the grounding kits on ebay are generally crap. I had one...the holders weren't crimped onto the wire ends and in general it would be worth it more to just buy wire and just make the grounding kit yourself.
Old May 16, 2005 | 07:30 PM
five-0's Avatar
Default Re: Grounding system really work? (xthephilx)
A magazine was installing a grounding kit on an H22 and running dynos at the same time. They actually lost horsepower by just straping things down t ground. There are strategic points to ground and in general... not worth it.
Old May 16, 2005 | 08:09 PM
AndyD's Avatar
Default Re: Grounding system really work? (five-0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by five-0 &raquo;</TD></TR><TR><TD CLASS="quote">A magazine was installing a grounding kit on an H22 and running dynos at the same time. They actually lost horsepower by just straping things down t ground. There are strategic points to ground and in general... not worth it.</TD></TR></TABLE>
Do you have a link?? What you said does not make any sense.
Adding more grounding points can only help the car run better.
Old May 16, 2005 | 08:44 PM
SIckH22Atch's Avatar
Default Re: Grounding system really work? (AndyD)
it couldn't hurt it.
The question is, "is it worth it" To me... no. I would save up and get something else. You can make your own kit for 1/3rd the price that will do the same thing. As far as "does it free up power?" Yes it does. I have seen 2 dyno graphs where the gain about 3whp.... thats not bad, but I would rather put the money elsewhere.
Old May 17, 2005 | 06:27 AM
Hawkze_2.3's Avatar
Do a little research and then just replace your stock grounds with good clean wire, and sand the mounting points totally clean so you have good connection.
Old May 17, 2005 | 07:01 AM
IHateJDM's Avatar
Default Re: Grounding system really work? (Hawkze_2.3)
just go to a local car audio shop and buy some wire and terminals. you can run whatever guage you want this way, and it'll cost under $10. I don't know if it really helps, but it can't hurt.
Old May 17, 2005 | 07:02 AM
Daemione's Avatar
Those "voltage stabilizers" (aka caps) are dumb. A healthy battery is the best cap you'll never need.
For $50+ shipped, buy the wire & hardware separate & put it together yourself.
Old May 17, 2005 | 07:55 AM
How the hell could you lose horsepower?? What about sound quality?
Old May 17, 2005 | 10:18 AM
IHateJDM's Avatar
Default Re: (ludewithanh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludewithanh22 &raquo;</TD></TR><TR><TD CLASS="quote">How the hell could you lose horsepower?? What about sound quality?</TD></TR></TABLE>
If you have an alternator whine in your speakers, it may help sound.
Old May 17, 2005 | 08:26 PM
five-0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
Adding more grounding points can only help the car run better. </TD></TR></TABLE>
Here is the link: http://www.importtuner.com/tech/0306it_ppprelude/
Read the paragragh below dyno notes. Hell... read the whole thing. It says "we actually lost power" somewhere. Anyhow.... still not worth it.
Old May 17, 2005 | 09:20 PM
prylwd's Avatar
Not worth it at all. Like the others said if you want one so bad just make your own. Or replace all your current grounds with fresh thicker gauge wire.
Old May 17, 2005 | 10:32 PM
apgarabu's Avatar
well, i put an Apex-I Super Grounding System on my H22 and i got 1.82 whp and approx 1 lb torque. Mind you, that it took 3 pulls on the dyno to acheive this. The OBDII seems to take a few runs to "learn." I dont think that just wires do the trick. Buy one from a big brand that has done the research. i bought one of those ebay brand grounding system, and i lost power. i guess the voltage stabilizer box on it does more.
here is the link to what i bought (at bottom)
http://www.apexi.com/product_electronics.asp
Old May 17, 2005 | 10:54 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludewithanh22 &raquo;</TD></TR><TR><TD CLASS="quote">How the hell could you lose horsepower??</TD></TR></TABLE>
Heheh, heat soak on the dyno.
Old May 17, 2005 | 10:56 PM
sharkcohen's Avatar
Default Re: Grounding system really work? (apgarabu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apgarabu &raquo;</TD></TR><TR><TD CLASS="quote">The OBDII seems to take a few runs to "learn." </TD></TR></TABLE>
That's not how the ECU works, and dynos can vary more than that from run to run without changing anything on the car.
Old May 18, 2005 | 05:21 AM
Daemione's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apgarabu &raquo;</TD></TR><TR><TD CLASS="quote">well, i put an Apex-I Super Grounding System on my H22 and i got 1.82 whp and approx 1 lb torque. Mind you, that it took 3 pulls on the dyno to acheive this. The OBDII seems to take a few runs to "learn."</TD></TR></TABLE>
Or more likely, the engine finally got up to operating temps.
Old May 18, 2005 | 06:38 AM
staticrex's Avatar
Default Re: Grounding system really work? (Daemione)
wow gained 7hp for $1500. That sucks.
gniddy
Oct 18, 2008 11:16 PM
FishyMan
Dec 26, 2006 01:01 PM
95accordh22a
Dec 10, 2004 06:50 PM
sk8erdude1386
Feb 18, 2004 05:24 PM
slowd16z6
18
Oct 13, 2003 08:34 AM
