Quick tensioner help
Old May 16, 2005 | 02:50 PM
6shootahorsenamedtrigga's Avatar
Default Quick tensioner help
Im about to go and install this guys auto tensioner after we find a compressor and gun to remove the probably 250 ft-lb tightened crank pulley bolt.....NE way real quick..how do you set timing before u release the auto tensioner...is it at TDC or is it 3 teeth past TDC like on B and D series?
Old May 16, 2005 | 03:21 PM
prelude1897's Avatar
Default Re: Quick tensioner help (mphinesee)
I just changed my timming belt yesturday...When taking your belt off, you need to have it TDC, same when you put it back on. It might be a good idea to swap to a manual tenisor, cause people have said the auto tenisor tends to go out.
Old May 16, 2005 | 03:27 PM
Default Re: Quick tensioner help (prelude1897)
tru..but this aint my car im just doin the work for this guy ...he didnt want to buy that manual conversion ****....but i just need to make sure before you tension the belt (release the autotension clamp/tool) do you do it at TDC or 3 cam teeth past TDC
Old May 16, 2005 | 07:13 PM
Honda Sport's Avatar
at TDC
Old May 16, 2005 | 07:54 PM
Default Re: (Honda Sport)
okay thanks...what about the rear balance shaft...do u really have to stick a bolt in the service port...i dont have that size bolt layin around and was wondering if there was some other way u could line it up to tdc......and also the pulley for the TIMING BELT: what is the torque spec on that adjusting bolt... could someone check real quikc,,,i dont have a helms for prelude
Old May 16, 2005 | 10:25 PM
33lbs on the adjusting nut. I didn't put my balance shaft belt on, just left it off, but I believe you can just stick in a screwdriver or something else to hold the balancer in place while you put on the belt. I just used a screwdriver for a f22a4 timing belt/head rebuild I just did recently.
misc tidbits for you guys:
the crank bolt needs 159lbs of tq
valve clearance:
intake .15-.19mm(.006-.007in)
exhaust .17-.21(.007-.008in)
adjust valves in firing order 1-3-4-2(1 starting from the driver-side, ending in 4 passenger-side) starting with cyl 1 at TDC. turn the crankshaft 360degrees(cams turn at half the distance so cams would turn every 90 degrees).
Modified by Honda Sport at 7:43 AM 5/17/2005
Old May 17, 2005 | 01:27 AM
thanks...ive done valves on his ride before..was somewhat harder than a ls but it was straight..but about the torque specs...well they arnt too spec..they are just about what i felt since getting my torqer in that hatch swap wanst gonna work.......thank for your help
Old May 17, 2005 | 09:21 AM
951dc5's Avatar
Default Re: (mphinesee)
yea just line it up at tdc with the flywheel mark on the pointer. u might want to align the mark of the oil pump pulley on the groove by the block
nemesis25
Jan 2, 2008 04:48 PM
tmrtwo
Feb 2, 2007 04:43 PM
david90
Oct 1, 2003 02:13 PM
