Performance question
Old May 18, 2005 | 05:18 PM
ludedudeh22's Avatar
Default Performance question
I have a 93 honda prelude with an h22, and I'm getting ready to rebuild the engine. I have a budget of $1000 to spend on performance parts. What should I do to get maximum horsepower? My ideas are to port and polish the head, get cams, and possibly port and polish my intake. Please let me know what I should do.
Old May 18, 2005 | 06:58 PM
edulerp97's Avatar
Default Re: Performance question (ludedudeh22)
NA or force induction....
Old May 18, 2005 | 07:12 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludedudeh22 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 93 honda prelude with an h22, and I'm getting ready to rebuild the engine. I have a budget of $1000 to spend on performance parts. What should I do to get maximum horsepower? My ideas are to port and polish the head, get cams, and possibly port and polish my intake. Please let me know what I should do.</TD></TR></TABLE>
You want port and polish head, IM, and cams? I don't thinks 1g is enough money.
Old May 18, 2005 | 08:14 PM
PrettyLude's Avatar
i think you should gather some more money and build the bottom end, i.e. sleeves, pistons, rods, and bearings, seals, and gaskets
Old May 18, 2005 | 08:22 PM
98vtec's Avatar
moderator emeritus
Default Re: (PrettyLude)
intake and a nice header
you gonna need atleast about 3k for a head build with head work.
But u need bolt ons before you go into the motor, so my vote is intake and a nice header. FYI, if you are thinking about a DC header.....dont waste your money, stick with the stock header if thats the case.
Old May 18, 2005 | 08:56 PM
I dont think that anyone understands my question because i didnt make myself very clear. My car is not stock I have : dc header, apexi world sport 2 exhaust, test pipe, msd sport compact ignition, msd wires, cold air intake. but that just isnt enough ***. i need to feel a horse power increase, and im not turbo or supercharging it (too much money).
I know that pistons change the compression but do they add horsepower. and does anyone know of a website where i can find a aftermarket head or if they even make such a thing.
Old May 18, 2005 | 09:49 PM
98vtec's Avatar
moderator emeritus
Default Re: (ludedudeh22)
you are going to go WAY over your 1k limit, hell a port and polish from a reputable place is almost 1k. ANd you cant just drop forged pistons in the block. YOu ahve to get the block sleeved. Plan on about 3k for the bottom end. and about 3k for the head and head work. Then you have to get it tuned...and not Vafc bullshit.
Old May 18, 2005 | 11:14 PM
Arch-Angel's Avatar
I agree with what the others have said- my head work cost in excess of $3000...
Considering you already have a handfull of bolt on's there, maybe you should consider an aftermarket engine management... You might be able to get a Hondata s200 bought and installed for under $1000- and that should hopefully give you a little extra power.
Old May 19, 2005 | 06:16 AM
edulerp97's Avatar
Being Fast isn't cheap .....
Old May 19, 2005 | 06:48 AM
98vtec's Avatar
moderator emeritus
Default Re: Performance question (edulerp97)
my favorite quote is "you gotta pay to play"
Old May 19, 2005 | 07:45 AM
Greyout's Avatar
Default Re: Performance question (98vtec)
If you have to pull the motor apart and rebuilt it, I'd say buy some Type S pistons & mill the head a little to get some compression, but thats it, because the rest of the money is going to be spent on seals, rings, bearnigs, gaskets, fluid, etc..
Old May 19, 2005 | 11:51 AM
The Phil's Avatar
$1000 is almost enough to get a nice homemade turbo setup. Go with that. Sell that DC header garbage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 &raquo;</TD></TR><TR><TD CLASS="quote">Being Fast isn't cheap .....</TD></TR></TABLE>
*Points and laughs at all the silly honda kids...
Old May 19, 2005 | 01:10 PM
PrecisionH23a's Avatar
Default Re: Performance question (xthephilx)
50-75 shot of nitrous and hondata. End of story.
You aren't going to get much gains with a port and polished head unless you add some sort of engine management. Skunk 2 cams would not be a bad choice... but you want to check to see which stage is going to benifit your current compression ratio. My guess is the stage 1. As far as milling the head goes, I wouldn't do that. See if you can pick up a thinner headgasket instead. And of course... if you go with cams you will also need some sort of engine management.
People who do 'budget builds' are the ones who end up paying 5x as much because they tried to save a few hundred dollars. I've seen this happen PLENTY of times.
Old May 19, 2005 | 04:18 PM
Lewdin' Incognito's Avatar
Default Re: Performance question (PrecisionH23a)
.....and a cooked piston due to an overshot isn't cheap either....
Old May 19, 2005 | 04:19 PM
98vtec's Avatar
moderator emeritus
Default Re: Performance question (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">.....and a cooked piston due to an overshot isn't cheap either....</TD></TR></TABLE>
wont happen if you arent dumb...50-75 tuned on hondata is easily taken.
Ryanh22aprelude
Jul 22, 2013 03:20 PM
michaelprice83
Feb 2, 2009 04:45 AM
reikoshea
21
Sep 13, 2006 09:51 PM
ludedudeh22
May 18, 2005 06:21 AM
951dc5
Oct 25, 2004 07:52 PM
