Performance help
Old May 17, 2005 | 04:52 PM
ludedudeh22's Avatar
Default Performance help
I have a 93 prelude and im getting ready to rebuild the engine. On top of that i am trying to get a little extra hp without spending too much. I have about a thousand dollars to spend on performance. What can i do for that amount of money to get the most horses and a bit more torque? I was thinking one or a few of the following would work: Shave the head, port and polish the head and intake, Cams, a new head, stroker kit. Please im begging anyone with more knowledge than me to write me back thanks!
Old May 17, 2005 | 05:12 PM
Lewdin' Incognito's Avatar
Default Re: Performance help (ludedudeh22)
If you go with head and cams, you've just spent at least half your $1000 depending on where you shop. There's nothing wrong with the H22 head, but it might be better for you if you find a good deal on one and build that up while you can still drive the lude. In my opinion, I would start with:
- cold air (or short ram) intake, if you haven't already
- header and exhaust
- possibly port n polish the intake manifold or go with an aftermarket one
- stiffen up the suspenion - strut bars
I would stay away from taking off the head until you have everything ready for it; it can get real pricey real fast - cams, p&p, valves, gears, etc. etc. (Even at that, it's easier to take the head and intake manifold off together)
If I were starting another on a budget, I'd go for getting the airflow as efficient as possible then saving up $, parts to do the other more involved stuff.
Good luck, hope it helps! Your bound to get 100 different opinions.
Old May 18, 2005 | 06:21 AM
RemerLex11's Avatar
Default Re: Performance help (Lewdin' Incognito)
Cold air intake, header, and exhaust are your best bet to start at
fireant
13
Dec 24, 2008 08:23 AM
Flexin5
11
Jun 4, 2006 05:31 AM
2ndgent3g
Nov 25, 2004 09:20 PM
kentuckyakord
Mar 30, 2004 08:05 PM
B19CivicHB
Jan 11, 2002 11:16 AM
