check engine problem!!!!!
Old May 16, 2005 | 07:58 PM
mprelude's Avatar
Default check engine problem!!!!!
ok my code says blink stops for a while then blink stops for a while then blinks 3 times wut is that 13 cause i changed my computer and it didnt help its either 1 or 3 or 23 cause my car hella lags with a check engine on please help
Old May 16, 2005 | 08:37 PM
SIckH22Atch's Avatar
Default Re: check engine problem!!!!! (mprelude)
are they 2 long blinks then 3 short? if so, that would be code 23.
here is the code list... 23 = knock sensor... which would retard your timing and put you in limp mode = your car runs like crap.
http://tech.hybridgarage.com/tech/codes.html
Old May 16, 2005 | 08:55 PM
mprelude's Avatar
Default Re: check engine problem!!!!! (SIckH22Atch)
where is the knock sensor located
Old May 16, 2005 | 08:57 PM
shdriver99's Avatar
somewhere that you don't want to have to go if you've got an SH OBD1 ludes and base ludes aren't as bad to get to and it's directly under the middle of the intake manifold! Should be a one wire sensor!
Old May 16, 2005 | 09:30 PM
mprelude's Avatar
Default Re: check engine problem!!!!! (shdriver99)
is it easy to change the knock sensor your self and wut else causes the car to limp
Old May 17, 2005 | 10:25 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mprelude &raquo;</TD></TR><TR><TD CLASS="quote">is it easy to change the knock sensor your self and wut else causes the car to limp
a lot of things can cause your car to run badly, too many to list. Make sure you get the right code, then let us know.
02spoon
Oct 17, 2010 09:48 AM
jdmland
Sep 4, 2008 11:17 AM
antballs420
Feb 20, 2006 06:35 PM
9deuce9rr
May 16, 2005 08:40 PM
aznplyboi15
Feb 14, 2005 09:37 AM
