H22 ring lands? Is this a common problem?....
Old May 11, 2005 | 11:08 PM
jdmcivicferio's Avatar
Default H22 ring lands? Is this a common problem?....
Why do the h22 piston ring lands blow out so easily compared to any other honda motor?
majority of h22's I have taken apart, always the ring lands are gone but block is fine, is there a problem with the stock pistons or something?
Old May 12, 2005 | 01:15 AM
happylude's Avatar
forced induction and cast pistons don't play well together. this happens with most cast pistons that get beat up by detonation whether it be an H22 or not. and the block is not always fine. my block had to be resleeved due to scarring on the cyl walls.
Old May 12, 2005 | 06:36 AM
Honda318dx's Avatar
Default Re: H22 ring lands? Is this a common problem?.... (jdmcivicferio)
yes, it is pretty common.. I had a h23 with NOS, yeap, ring lands broke
Old May 12, 2005 | 06:55 AM
Hawkze_2.3's Avatar
Yup, this is a common problem and the main obstacle for anyone who wants to make serious power. Then you have to sleeve the block to run forged pistons, so on and so forth...
Old May 12, 2005 | 10:10 PM
Default Re: H22 ring lands? Is this a common problem?.... (Hawkze_2.3)
do you "have" to sleeve the bottem end or can you just put pistons in
Old May 12, 2005 | 10:11 PM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio &raquo;</TD></TR><TR><TD CLASS="quote">do you "have" to sleeve the bottem end or can you just put pistons in</TD></TR></TABLE>
if you run forged pistons, you have to resleeve, cuz of frm
Cmanning816
Feb 14, 2014 07:07 AM
mudpuppy4life
Aug 5, 2011 08:48 AM
h22_crx
Apr 16, 2006 09:12 AM
VtecPrelude93
Jul 9, 2005 12:50 PM
JDM_4thGen
Jun 26, 2002 10:59 AM
