CHECK ENGINE LIGHT
Old May 12, 2005 | 12:33 PM
DAcraze's Avatar
Default CHECK ENGINE LIGHT
hey guys, how do u pull the check engine code on a 98 prelude???
Old May 12, 2005 | 12:34 PM
DAcraze's Avatar
Default Re: CHECK ENGINE LIGHT (DAcraze)
i meant an 01 prelude
Old May 12, 2005 | 12:38 PM
J.B.'s Avatar
take it to Autozone they read do it for free~
Old May 12, 2005 | 01:36 PM
xbn83's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAcraze &raquo;</TD></TR><TR><TD CLASS="quote">hey guys, how do u pull the check engine code on a 98 prelude???</TD></TR></TABLE>
There is a service connector on the right of the shifter assembly. If you sit on the passenger side, it is on your left leg. Pull the cover out, there is 2 pin connector. Jump it by putting a paper clip in both sides. Turn the key on. Take note of how many slow blink and fast blink check engine light gives out. For example, if you have code 22 it will blink 2 slow one, pause lil bit, then 2 fast one. It will repeat like that over and over again. Sometimes you have more than 1 code, watch couple times to make sure.
Old May 12, 2005 | 01:54 PM
98TypeSH's Avatar
Default Re: CHECK ENGINE LIGHT (xbn83)
Here you go, keep this handy.
http://hondaprelude.to/article....html
Old May 12, 2005 | 02:48 PM
DAcraze's Avatar
Default Re: CHECK ENGINE LIGHT (98TypeSH)
thanks we got it just a few mins ago
Climbtrees
Jul 26, 2012 01:32 PM
noood
Jan 18, 2008 06:22 AM
bchomka
Feb 2, 2005 06:31 PM
importdude2000
Jul 17, 2004 12:53 PM
