4th Gen Headlight Problem...
Old Jul 13, 2005 | 12:12 PM
AnthonyG2003
Guest
Posts: n/a
Default 4th Gen Headlight Problem...
Has anyone had problems with their headlights on the 4th gen preludes? My headlights only come on sometimes, and then I cant get them to come on for a while. I was just wondering if anyone in here has had that same problem, and if so...what was done to fix it!? Thanks!
Old Jul 14, 2005 | 12:19 PM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: 4th Gen Headlight Problem... (AnthonyG2003)
I've never heard of that. My best advice is to carefully check all of the wiring/connections.
Old Jul 14, 2005 | 05:00 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: 4th Gen Headlight Problem... (92prelude)
This problem just started here about 3 days ago and I havent been able to drive the prelude at night, I miss her! The running lights and the turn signals all work that are on the same switch, it is just the headlights that will not come on...
Thanks for the advice, Ill check as much of the wiring that I can...I am no electrician!
If anyone else has any advice or tips...Please let me know! Thanks!
Old Jul 15, 2005 | 05:42 PM
AnthonyG2003
Guest
Posts: n/a
Just to keep everyone posted (if anyone cares). I forgot to check my Headlamp Relay...So now they are working! Thanks for the advice!
Old Apr 7, 2006 | 12:02 AM
AznBlueBoy's Avatar
just wondering where is the headlamp relay?
i am having the same problem and sometimes my headlights just turn off while im driving on the highway at night which could be scary and i have to wait a bit and keep trying to turn them back on
is that the same problem you had?
Old Apr 7, 2006 | 05:04 AM
94vtecmn's Avatar
Default Re: 4th Gen Headlight Problem... (AznBlueBoy)
Its in the under hood fuse box, and is certainly your problem.
Old Apr 7, 2006 | 05:58 PM
AznBlueBoy's Avatar
Default Re: 4th Gen Headlight Problem... (94vtecmn)
alright how would i know if the relay is messed up?
do i have to just buy a new one?
and theres also a dimmer relay next to it, do you guys know what that is?
my interior lights like my gauges and gas/temp gauge are really dim, is that the relay that could mess that up as well?
Old Apr 7, 2006 | 06:43 PM
AnthonyG2003
Guest
Posts: n/a
Try to plug your ABS relay into your headlight relay...If it works...Then your headlight relay is gone/going bad.
Old Apr 7, 2006 | 07:39 PM
Altilude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznBlueBoy &raquo;</TD></TR><TR><TD CLASS="quote">
i know you got a 4th gen from vancouverpreludeclub.com (seen ya there) - so in any case - on 4th gens (atleast mine!) there is a roller dial for the dimmness setting of the guages (maybe you know this? it's to the left of the steering wheel) in any case if you roll it all the way up it clicks into a detent - that will be max bright... perhaps this isn't your issue, but believe it or not - i've seen it asked before.
best of luck.
Old Apr 7, 2006 | 07:52 PM
AznBlueBoy's Avatar
Default Re: 4th Gen Headlight Problem... (Altilude)
its not that because when i turn it up all the way
half the stuff doesn't light up
like half the gas will be really bright but the middle part will be blank like its burnt out bulbs or something which its not.
Old Apr 7, 2006 | 08:00 PM
Altilude's Avatar
that sounds quite odd, i mean the bulbs are wired in parallel (ie: when one burns out all the rest don't stop working as they would if it were in series) so they should technically all be putting out the same brightness, unless someone used some wrong/different bulbs.... i'd pull out the cluster and fiddle with it while it's removed. it's a seperate cluster then the one you're talking about... but I know the speedo cluster prior to EL gauges sucked the big one, because the plastic deteriates over time, so then some bulbs don't click into there detent so they aren't actually making contact with that trace circuit... i got one out on my rpm bugs the hell out of me.
give an answer if you figure it out.. had to go thru the dimmer dial speil just incase it was something you had missed. \-:
failing all that, you could always buy the gas/temp/indication cluster on ebay i've seen them from time to time. maybe you'll get one with the smoky cat. sweet.
Old Apr 7, 2006 | 08:07 PM
AznBlueBoy's Avatar
i did buy a new gas/temp gauge and its the same thing
so im thinking its some wiring or possibly the relay
sometimes it flashes bright and dimming then sometimes it stays bright
its weird....
tuan...
Dec 15, 2006 03:32 AM
Ludester
Nov 9, 2003 07:45 PM
